Last updated by Rohan Sadanandan 5 months ago.
Assigned support staff: Rohan Sadanandan.
September 20, 2019 at 1:42 am #4608561
patrickL-43
I am trying to: use an ajax call to display products and have the language match
I expected to see: Spanish Products
Instead, I got: English Products
September 20, 2019 at 5:37 am #4609905
Rohan Sadanandan
Please go to WPML > Languages and scroll down to the “Language filtering for AJAX operations” section. Please check the option to "Store a language cookie to support language filtering for AJAX". Then log out, clear your browser cache, and log back in.
Please let me know if this does not resolve the issue for you and I will take another look.
Also, I request you to update all the WPML plugins to the latest version.
Rohan
September 20, 2019 at 6:01 pm #4614031
patrickL-43
Hello, thank you for your response.
Yes, I checked that option yesterday when I was browsing through support forums here. That unfortunately did not help, neither did the 'surpress_filter' options, I tried '0', '1', 'true' and 'false'.
Here is my loop:
if(!empty($_POST["cat_slug"])){
$curr_cat = $_POST['cat_slug'];
}else{
$curr_cat = 'carton-sealers';
$new_query = array(
'relation' => 'AND',
$conditions
$args = array(
'posts_per_page' => -1,
'post_type' => 'product',
'suppress_filters' => 2,
'tax_query' => array(
array (
'taxonomy' => 'product-category',
'field' => 'slug',
'terms' => $curr_cat,
'orderby' => 'menu_order',
'order' => 'ASC',
'paged' => $page_num,
'meta_query' => $new_query
$the_query = new WP_Query( $args );
September 23, 2019 at 6:38 am #4620681
Rohan Sadanandan
Thanks for your patience & sorry for the delay.
I was just checking your code & it seems that you are fetching the products based on the terms "$curr_cat"
Could you please confirm that the translation of the term exists & you are passing the correct value in the $curr_cat variable?
Rohan
September 25, 2019 at 9:01 pm #4642051
patrickL-43
Yes, there are direct translations for each product category, I have also tried hardcoding my category ID, using the English and Spanish options.
No matter what I call, the english products display.
September 26, 2019 at 11:27 am #4646283
Rohan Sadanandan
Thanks for the details.
Could you please test in a minimal environment by disabling all plugins that are unrelated to WPML and switch to one of the default themes e.g. Twenty Fifteen, Do you see the same issue?
If the custom post type you are querying is created by either a plugin or a theme please leave them on. This will allow us to test if there are any other filter hooks manipulating the query.
Also, can you confirm if the "product" post type is configured to use a fallback language? This configuration can be found here: https://wpml.org/documentation/translating-your-contents/displaying-untranslated-content-on-pages-in-secondary-languages/
Rohan
The topic ‘[Closed] When using AJAX to Query posts, it only shows default language products’ is closed to new replies.
