Last updated by Mona 5 years, 6 months ago.
Assigned support staff: Amber Martin.
July 10, 2014 at 10:30 pm #434166
Mona
I have a white screen on the settings of WPML String Translations.
Here is the WP_debug report:
Notice: wpdb::escape est déprécié depuis la version 3.6! Utilisez wpdb::prepare() or esc_sql() à la place. in /var/www/khabarelyom.com/wp-includes/functions.php on line 3078
Thanks in advance for your help. I can send you my FTP and WordPress credentials if needed.
July 11, 2014 at 1:13 pm #434613
Amber Martin
Send me your credentials so I can take a look.
Amber
July 11, 2014 at 4:28 pm #434774
Mona
Thanks for your quick reply. Here are my credentials. (Port is filled out in "folder" field)
July 11, 2014 at 5:09 pm #434781
Amber Martin
You will need to update your plugins. You are using outdated versions of WPML.
Please update WPML to 3.16 should fix the issue.
Amber
July 11, 2014 at 6:48 pm #434812
Mona
Big big big fail, sorry about that, I don't even know how these outdated versions of WPML are here, I made a wrong manipulation. Then, no notification to let me know that the plugin is outdated. Sorry again and thanks for your great work, you can even remove this topic 🙂
