Our next available supporter will start replying to tickets in about 0.86 hours from now. Thank you for your understanding.
Last updated by Jamal 11 months, 3 weeks ago.
June 7, 2019 at 4:00 pm #3977577
nicolaH-2
I have set up the page in 4 languages using WPML for translation purposes and it works fine. The only thing not working is the translation of the widgets next to the products of the shop. I have translated all strings which are necessary for these widgets, but it is only working in German (original language) and not showing at all in all other 3 languages. What am I doing wrong?
I have tried to duplicate the widgets and set each one in 1 language only, but it is still not working.
June 7, 2019 at 4:36 pm #3977745
Jamal
Timezone: Africa/Casablanca (GMT+00:00)
This may be caused by an incompatibility with your theme or another plugin, on your test site, please check if this issue appears when:
- Only WPML plugins are activated. It will tell us if there is an interaction issue with other plugins.
- Theme is set to a WordPress default like Twenty Fourteen. It will tell us if there is an interaction issue with your theme.
- If the problem disappears, start activating one at the time to track where the incompatibility is produced.
I assume, you have disabled the widgets, as I could not find the issue on your shop page. Can you add a screenshot of the issue and a link to a page where we can see it?
Jamal
WPML Support
The topic ‘[Closed] Widget problem’ is closed to new replies.
