Last updated by Lauren 11 months, 2 weeks ago.
June 10, 2019 at 6:09 pm #3989503
thomasK-90
I am using Genesis featured page advanced widget and would like to translate them.
I followed the steps described on this page.
https://wpml.org/forums/topic/translate-widgets-created-with-the-plugin-genesis-featured-page-advanced/
However, custom_content is not appearing in String Translation. I could translate the titles.
June 10, 2019 at 7:40 pm #3989977
Lauren
Were you able to find the strings in WPML -> String Translation -> Admin Texts? If you found them but were unable to add them to string translation, most likely you need to increase max input vars. You can do this by adding this line to your .htaccess file:
php_value max_input_vars 20000
or by following these steps:
1. Connect to your site via FTP or File Manager
2. Navigate to wp-admin folder
3. Create a file inside wp-admin folder called php.ini
4. Add in this line: max_input_vars = 20000
5. Save
If you don't have access to these files, please ask your hosting provider to do this for you.
June 10, 2019 at 7:54 pm #3990055
thomasK-90
Tried your suggestion, but still I cannot add them to string translation.
June 11, 2019 at 1:15 pm #3995627
Lauren
You can try adding them to WPML -> Settings -> Custom XML Configuration. You can follow the steps in this documentation and add the fields there: https://wpml.org/documentation/support/language-configuration-files/
Once you have added them there, they should appear in the String Translation table. Please let me know if you need any further assistance and I will be happy to help.
June 11, 2019 at 5:43 pm #3997783
thomasK-90
I found them in the string tranaslation without Custom XML method. It was simply in other domain than I thought.
Now I translated and some appear on the frontend correctly, but some don't, even they are translated. Why?
June 12, 2019 at 4:49 pm #4006267
Lauren
It could be that you have translated the incorrect string, they could be located in a different domain in the admin texts. I'll be happy to take a look if you would like. Please let me know the URL where I can see the strings on the frontend,and also where you go to edit or create the content on the backend.
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
June 13, 2019 at 1:17 pm #4013201
Lauren
Thanks for sending me access. I see that when you created the content in Appearance -> Widgets -> Front Page 2, you entered the title in English. However, your default language is German. So what happens is that the string is registered in German in WPML -> String Translation. In my screenshot, you can see that the Widget Title has not been translated. I suggest updating the widget title to German. Then, go to WPML -> String Translation and search for the title and translate it to English.
Once you have completed those steps, please let me know if you are still seeing untranslated texts.
June 13, 2019 at 4:35 pm #4015701
thomasK-90
I followed your suggestion but still seeing untranslated texts.
June 14, 2019 at 4:45 pm #4023097
Lauren
I found that you can translate these widgets by creating a widget for each language. At the bottom of the widget, you should see the language selector. I set the one you created to DE and then added a new one and set it to EN. Now you can see the correct one showing up in each language for Automotive Aftermarket.
You can follow these steps for the additional widgets. Please let me know if you need any further assistance and I will be happy to help.
