This topic contains 12 replies, has 4 voices.
Last updated by sarah.n 6 years, 10 months ago.
Assigned support staff: David.
June 12, 2013 at 12:30 pm #135179
Neil
We are working on a custom woocommerce wpml integration. We are using a custom woocommerce add to cart function like this:
$woocommerce->cart->add_to_cart( $product_id, $item['quantity'], '', '', $cart_item_data )
When WPML is enabled the productid and quantity are passed ok, but the $cart_item_data is not
When I disabled wpml this works fine.
Here is the array data for $cart_item_data
array(1) {
["linen_item_meta_data"]=>
array(6) {
["fabric_shape"]=> string(9) "rectangle"
["color"]=> string(4) "noir"
["finish"]=> string(10) "chevron-fr"
["final_length"]=> string(3) "137"
["_price"]=> float(24.78)
["final_width"]=> string(3) "137"
Any pointers to fix this would be appreciated
June 12, 2013 at 3:43 pm #135289
Harshad
Dear Neil,
Does it works for default language product, or it doesn't work in both default and secondary language product id when wpml is enabled?
June 12, 2013 at 3:47 pm #135295
Neil
It doesn't work on either language.
June 14, 2013 at 10:55 am #135868
Neil
Hi just checking if you were able to recreate this issue, would you like a login to my site to see the problem?
June 14, 2013 at 1:29 pm #135907
David
Dear Neil,
I wasnt able to reproduce it, seeing a bit of the code around that line would surely help. I will write to you an email requesting access. Let me know if you dont receive it.
Best,
David
June 20, 2013 at 10:39 am #137487
Neil
Hi David
Have you had a chance to look at the code?
Neil
June 25, 2013 at 1:32 pm #138835
Neil
Just bumping this support thread again, our project is stalled until we can get a fix
thanks
June 26, 2013 at 3:20 pm #139325
Neil
Hi Guys any update?
I understand you are busy but can I get an idea that you are still looking into my issues.
July 2, 2013 at 9:53 am #140789
sarah.n
Neil,
This is Sarah and I am answering in behalf of David. We have not forgotten about you, in fact I had a look inside your installation and I can see the problem.
Let me touch base with David and get back to you. Thank you for your patience!
July 3, 2013 at 11:32 am #141234
sarah.n
Neil,
We need temporary FTP access to the dev install you set-up for us. I'll email you shortly about it. Please stand by.
July 3, 2013 at 2:09 pm #141279
sarah.n
Neil,
This is to inform you that I have received your email reply. Thank you.
I have uploaded a new version of WCML with a fix that David added in and have confirmed that it works.
Can you please test once more to confirm it works on your end as well?
July 4, 2013 at 8:27 am #141516
Neil
That has worked beautifully thanks for all your help - just out of curiosity what was the problem?
July 5, 2013 at 8:22 am #141853
sarah.n
See: http://plugins.trac.wordpress.org/changeset/716071/woocommerce-multilingual/trunk/woocommerce_wpml.class.php
