Last updated by Fabio Massimo Pari 8 months, 4 weeks ago.
September 10, 2019 at 6:12 am #4542089
Fabio Massimo Pari
This morning we update to 4.6.7 WooCommerce Multilingual. Previously we have 4.6.6.
Now the backend indicate problems with 3 part of WPML not updated.
This is not true, the plugin we use are already updated.
As a verification, we try to update to wpml-string-translation.2.10.6 and the update don't work 'cause already installed.
September 10, 2019 at 6:28 am #4542127
Alejandro
Hello!
Welcome to WPML Support.
I'll do my best to help you solve this issue.
From what i can see. you have WPML 4.1.4 instead of 4.2.8
you also have:
String Translation 2.9.2 instead of 2.10.6
Translation Management 2.7.3 instead of 2.8.7
Please update them or, if you feel everything's working ok in your setup, maybe run some tests and make sure it's that way and leave it as it is.
That notification exists to let you know that the version you are running of WooCommerce Multilingual is supposed to be paired with the most recent versions of the other plugins, to ensure the best compatibility between them.
Regards.
September 11, 2019 at 6:01 am #4550779
Fabio Massimo Pari
