Our next available supporter will start replying to tickets in about 1.13 hours from now. Thank you for your understanding.
Last updated by Petros 6 years, 3 months ago.
Assigned support staff: David.
June 19, 2013 at 11:13 am #137170
Petros
I have a problem with WooCommerce Multilingual plugin:
"WooCommerce Multilingual is enabled but not effective. It requires WPML Translation Management in order to work." I have installed the "WPML Multilingual CMS". I have also uploaded an image of the message along with all of my plugins.
Thank you, Petros.
June 20, 2013 at 8:25 am #137431
David
Hi Petros,
You need to install the plugin called "WPML Translation Management". You will find it in the downloads section or you can use the installer plugin.
Best,
David
June 25, 2013 at 2:13 pm #138859
Petros
Yes thank you it worked.
