Last updated by sarah.n 6 years, 11 months ago.
Assigned support staff: sarah.n.
January 29, 2013 at 9:10 am #100086
Bjorn
I'v treid to apply a different price manual in one of my translated products, but everytime i hit "update" it just resets, and goes back to the original number.
However, it shows the right "DKK" sign insted of €, but i its still 379DKK as it was 379€ it should be 2600DKK.
When i do the "Automatically calculate pricing in different currencies, based on the exchange rate" it works fine on all products, but i leaves me with something like this "2671,98 DKK" and that looks terrible...
When i click the checkbox "I will manage the pricing in each currency myself" in WPLM WooCommerce, i should be possible to set my own price on each product?
January 29, 2013 at 10:58 am #100141
sarah.n
Bjorn,
I will try to replicate the issue and get back to you.
January 29, 2013 at 11:00 am #100145
Bjorn
Okay, Sarah.
Thank you. I really hope you can sort it out.
January 29, 2013 at 11:29 am #100152
sarah.n
Bjorn,
As I have access details form you for the other thread you have open I will use them for this issue as well. Hope this is OK with you.
January 29, 2013 at 11:31 am #100154
Bjorn
Hi Sarah,
THANKS! That's great, the problem is solved 😀 - Good you figured that out.
And sure, you can just use my info on that thread as well, thanks.
//Bjørn.
January 29, 2013 at 11:43 am #100164
sarah.n
Bjørn,
I think you marked the wrong thread as resolved. Can you please open a new thread for the pricing problem? I will not be able to see your comment updates otherwise.
January 29, 2013 at 11:56 am #100174
Bjorn
Sorry.
New thread started here:
http://wpml.org/forums/topic/woocommerce-pricing-problem-2/
January 30, 2013 at 11:18 am #100478
sarah.n
