If you're experiencing a 'page not found' error when trying to access product category pages on your translated WooCommerce site using WPML, the issue might be due to missing translations.
We recommend checking the WPML → Taxonomy Translation → Product Categories to ensure that the Plural translation field is not empty. If it is, fill in the missing translation. Next, remove the product-category slug from String Translation, update the permalinks, and re-translate the slug. This should resolve the 404 error.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at https://wpml.org/forums/ for further assistance.
Last updated by hansN-10 4 months, 2 weeks ago.
Assisted by: Andrey.
July 14, 2025 at 6:45 pm #17235351
hansN-10
I am trying to access product category pages on my translated site using WPML for my WooCommerce store at hidden link.
I get "oops that page can not be found" when trying to access product category pages on my translated site.
Why are the product category pages not found on my translated site?
July 14, 2025 at 8:07 pm #17235571
Andrey
WPML Supporter since 06/2013
Please try the following steps to resolve the issue:
1. Go to WPML → String Translation.
2. Search for the string “product-category”.
3. Delete the string from the String Translation table.
4. Go to Settings → Permalinks and click Save Changes to refresh your permalinks.
5. Navigate to WooCommerce Multilingual and re-add the translation for the product category.
6. If the category is already translated, try synchronizing your menu again.
Please ensure you back up your database before making any changes.
July 15, 2025 at 9:08 am #17236920
hansN-10
Hello Andrey and thank you for your reply.
I followed your instructions 1-4.
5: Do you mean Woocommerce Multilingual > Store-URL:s tab? Yes, the translation is alrady there (see screenshot)
6: Do you mean WPML > WP menu sync? There is nothing that can be syncronized there, see screenshot 2
The issue is still there after doing the above.
Maybe I should clarify that it is ALL the product categories that are not working for the translated language (English). It is not just a single product category that has problems, so is there a setting that is wrong that is causing this?
Hans
New threads created by Andrey and linked to this one are listed below:
https://wpml.org/forums/topic/split-the-link-on-the-translated-english-page-still-points-to-the-swedish/
July 15, 2025 at 1:16 pm #17237970
Andrey
Thank you for your feedback, Hans.
Yes, you are correct.
However, please try to temporarily deactivate all plugins except WPML, WooCommerce, and WooCommerce Multilingual to check if the issue persists.
July 16, 2025 at 2:28 pm #17242676
Andrey
Thank you for the details, Hans.
I was able to identify and resolve the issue. In WPML → Taxonomy Translation → Product Categories, the Plural translation field was empty, which caused the 404 error. After filling in the missing translation, I removed the product-category slug from String Translation, updated the permalinks, re-translated the slug, and the issue was resolved.
We’ve reported this to our development team for further investigation.
Additionally, I’ve opened a separate support ticket regarding your other issue, and I’ll continue assisting you there:
July 16, 2025 at 4:55 pm #17243098
hansN-10
Thank you Andrey, that worked!
