You want to translate the product category in the URL from English to French and German using WPML, but after making the change, the page becomes unavailable.
We found that the issue was due to the Product base and Product category base translations being identical, which caused conflicts when displaying the product correctly. To resolve this, change the Product category base to a different value than the Product base. You can use a translation or simply modify the original value slightly to avoid conflicts.
If this solution does not apply to your case, or if it seems outdated, we recommend opening a new support ticket. Also, check the related known issues and ensure you have the latest versions of themes and plugins installed. For further assistance, please visit our support forum.
Last updated by Rob Coers 6 months, 1 week ago.
Assisted by: Andrey.
May 23, 2025 at 12:28 pm #17066243
Rob Coers
I want to translate the product category in the URL from English ('mobile-light-tower') to French ('tours-declairage') and German ('mobiler-lichtmasten') using WPML. The site I need help with is hidden link. The product in question is hidden link.
When I make the change in WPML, the page can no longer be found.
Why does the page become unavailable after changing the product category URL in WPML?
How can I successfully translate product category URLs using WPML without causing errors?
May 23, 2025 at 7:33 pm #17067754
Andrey
WPML Supporter since 06/2013
To help me better understand the issue, please upload any relevant screenshots or share links that illustrate the problem clearly. This will allow me to provide you with the most accurate and effective solution.
In the meantime, have you tried resaving your permalinks by going to Settings → Permalinks and clicking Save Changes without modifying anything? This can often resolve URL-related issues.
May 24, 2025 at 5:31 pm #17068953
Rob Coers
Hi there Andrey,
Thanks for picking up my question. Reading back my ticket, i realize i forgot to add this screen recording. Does this clarify the issue?
May 26, 2025 at 2:05 pm #17073740
Andrey
Thank you for the screencast.
Please try the following steps:
1. Go to WPML → String Translation and search for "mobile-light-towers".
2. Delete any entries related to "mobile-light-towers".
3. Navigate to Settings → Permalinks and re-save the permalinks using the custom base "mobile-light-towers".
4. Then, try translating it again.
Let us know if the issue persists after these steps.
May 27, 2025 at 12:46 pm #17078520
Rob Coers
Hi Andrey,
I can follow your steps and they make sense... however, i can't get it to work as you can see here: hidden link
Is there a way i can safely share login credentials with you?
May 27, 2025 at 2:19 pm #17079248
Andrey
Thank you for the nice explanation.
Product base is what you have set in Custom base in Settings → Permalinks, so it is okay.
Yes, sure. I need to request temporary access (wp-admin and FTP) to your site—preferably to a test site where the problem has been replicated if possible—in order to be of better help. When you log in to leave your next reply, you will find the needed fields below the comment area. The information you will enter is private, meaning only you and I can see and access it.
May 27, 2025 at 3:23 pm #17079515
Andrey
Hello Rob,
Good news — I was able to resolve the issue.
The problem was caused by the Product base and Product category base translations being identical, which led to conflicts when displaying the product correctly. I resolved this by changing the Product category base to a different value (just copied from the original but you can translate it).
I have attached the screenshot for your review.
May 28, 2025 at 6:55 am #17081392
Rob Coers
Solved, and very good to know the reason why it didn't work in the first place.
