Last updated by Dennis 11 months, 3 weeks ago.
Assigned support staff: Dennis.
June 12, 2019 at 9:01 pm #4007655
svenU-4
Hello! 🙂
I just translated many Products on my WooCommerce Store - but at some point it just did not upload the translations and there is a loading circle instead of a pencil for every new translation I create.
June 13, 2019 at 6:49 am #4009711
Dennis
Welcome to WPML Support forum.
Could you please confirm that you are using the updated copies of WPML/WCML plugins? Are you using ATE (Advanced Translation Editor) for translating products?
Kindly share your Debug information with me? You can read the detailed explanation about it here.
http://wpml.org/faq/provide-debug-information-faster-support
The debug info will give me a lot of information about how your site is configured and will help me understand the source of the problem.
Kind regards,
Dennis
June 13, 2019 at 12:58 pm #4013057
svenU-4
Yes, I am using an updated version of WPML. I used the ATE. I included the Debug information for you.
Thank you for helping
June 14, 2019 at 1:44 am #4017469
Dennis
Thank you for your reply.
We have similar issue reported to us which is currently being investigated by our developers. The issue is with WCML + ATE.
We also found a workaround for this.
After saving the translations with ATE, please:
- go to WPML > Translation Management
- find the product and send it to translation
- go to Translation Basket and send it to translation
- then go to WPML > Translations and now the translation should be saved and the 2-arrows circle icon should transform into the pencil icon
Now, if you also go to WooCommerce > WooCommerce Multilingual, you will see that the product translation should show the pencil icon.
Does it help? Please let me know.
Kind regards,
Dennis
The topic ‘[Closed] WooCommerce Product Translation does not work’ is closed to new replies.
