Last updated by Andreas W. 1 year, 4 months ago.
May 22, 2019 at 7:43 pm #3868901
konstantinosP-12
I found a lot of threads discussing the same issue but i haven't manage to solve mine.
I'm using two languages, French & English.
When i started building the website the default language was English. After i finished adding pages and products my client ask me to make French the default language.
Now, French is the default language but all products in French have locked fields.
How can i unlock them for French and lock fields only for English translations ?
Thanks in advance
May 22, 2019 at 11:53 pm #3869777
I am not sure if I understand the issue.
Do you mean you are not able to edit the products on the product editor? Did you try to decativate WooCommerce Multilingual? Will this solve the issue?
If so, please reactivate WooCommerce Multilingual and go to WooCoommerce -> WooCommerce Multilingual -> Status and click the option "Troubleshooting" at the right bottom corner of the string. Here please run all available sync options.
Does this solve the issue?
Kind regards
May 23, 2019 at 8:41 am #3872627
konstantinosP-12
Hello Andreas,
Thank you for your reply.
Yes, I'm not able to edit fields ( Price, inventory etc) in WooCommerce products on the default Language.
Deactivating WooCommerce Multilingual solved the issue.
Activating WooCommerce Multilingual again brings back the issue even if i run all sync task through Troubleshooting.
May 23, 2019 at 12:32 pm #3874991
konstantinosP-12
Is there any solution to my issue ?
May 23, 2019 at 2:43 pm #3877005
I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. It would be better to a testing site where the issue is replicated.
Maybe I'll need to replicate your site locally. For this, I’ll need to temporarily install a plugin called “Duplicator” on your site. This will allow me to create a copy of your site and your content. Once the problem is resolved I will delete the local site. Let me know if this is ok with you.
IMPORTANT
Kind regards
May 23, 2019 at 9:33 pm #3879457
It is default bahvior of WPML and WooCommerce Multilingual that product that have been created an a specific language will always have to be edited in the same language.
You can verify the orginal language of each product by going to WooCommerce -> WooCommerce Multilingual -> Products.
Each product includes a language flag which refers to the language inwhich the product has been created. If you now click on one of the products the product editor will open automatically choosing the admin language for the repsective product, which you can verify in the top admin bar.
We advise to always use the WooCommerce Multilingual Interface as reference when it comes to translate products.
I hope this answered your question.
Kind regards
