Problem: I would like to change the language of my WooCommerce product.
Solution: There is no automatic feature to do this but it can be done with this workaround (provided that product is not yet translated).
1. Duplicate the product from source language to the new language 2. Then edit the new language product and click on the "Translate independently" button 3. Edit the source language product and translate the contents to another language (or remove it if you don't want this product in this language)
Last updated by Dan 4 years, 9 months ago.
Assigned support staff: Pierre.
April 22, 2015 at 2:31 pm #604145
Dan
I am trying to: Finish a woocommerce website in Hebrew with English option.
The default wpml and wp language right now is English, but the woo products are all set as English, but the content is in Hebrew.
How should I fix or correct the hebrew products to be set as english. Duplicate and just translate ?
Sincerely
Dan
April 23, 2015 at 2:10 pm #604899
Pierre
Languages: English (English ) French (Français ) Portuguese (Brazil) (Português )
Hi Dan,
If I clearly understand your problem, I would suggest to do the following:
1. Duplicate the product to hebrew
2. Then edit the hebrew product and click on the "Translate independantly" button (in the "Language" block, see scrrenshot)
3. Edit the english product and translate the contents to english
Depending on the amount of products you have, you may use the WPML > Translation management interface for bulk process.
Let me know if this helps.
Pierre
April 23, 2015 at 3:28 pm #604961
Dan
Hi Pierre,
I managed to do just that, and it's ok, but why some options are not available to select on my Enfold theme ?
I think the Enfold theme developer overwritten some of the features.
I need to finish a Hebrew/English site tomorrow, and I feel like WPML is either one big mess of different settings, or perhaps you can recommend the BEST and Most compatible theme with WPML for Hebrew English.
Please help
Dan
April 23, 2015 at 4:28 pm #604995
Pierre
Dan,
I can't tell you if one theme or another is better for hebrew. But I can suggest you to have a look in our theme's compatibility list here: http://wpml.org/documentation/theme-compatibility/
One thing which may be important for hebrew language is RTL (right to left) support. This feature is not related to WPML so it's better to check with the theme's author.
If you have any question about theme's compatibility or other topic, please feel free to open a new thread.
Pierre
May 5, 2015 at 9:21 am #611949
Dan
Hello Pierre,
I want to have one language for now, Hebrew, and add the English later on.
I have all the products in Hebrew as a nice csv with sku numbers etc'.
How should I start a clean wordpress install for example with Divi theme ?
How should I approach the wpml install ?
Example:
Should I install normal english version on wordpress, then install Divi, and then when I install WPML, it would ask me if the site is in English or Hebrew.
What should I tell the wizard then ?
Should I skip wpml, define my wp install language to Hebrew, import the hebrew products, and install wpml later on once I'll need the English version ?
Dan
