Problem: Woocommerce Products tags not showing as translated - there are more than 1000 Solution: Set this in wp-config.php:
define( 'WPML_TAXONOMY_TRANSLATION_MAX_TERMS_RESULTS_SET' , 3000);
Just before the "/* That's all, stop editing! Happy publishing. */" line. It resolved the issue for me on the localhost Installation.
Not only that translated tags don't show any more, but I am also able to translate tags directly from WooCommerce multilingual panel. The reason for this seems to be the sheer number of tags (when you see that message that there are over 1000 tags). Adding this constant is an official workaround, but this issue has been escalated to our WooCommerce multilingual developers as well.
0% of people find this useful.
Last updated by Bruno Kos 1 year, 1 month ago.
Assigned support staff: Bruno Kos.
June 28, 2019 at 9:03 am #4105807
MCL van den
We are using the Woocommerce Multilingual to translate the products tags. All went fine until a few days ago.
When we translate product tags that aren't translated yet and we save them, they show up as translated with a pen icon. But after we refresh they show up as if they aren't translated anymore with a plus sign.
But there is still a translation in the products tags page. But it seems like they aren't linked anymore.
June 28, 2019 at 12:05 pm #4107183
Bruno Kos
Can you tell me if you're able to test this with the following scenario:
- deactivate all the plugins and leave WPML, WPML addons and WooCommerce active only
Let me know if you have trouble testing this in that scenario - I'm simply trying to exclude whether this has something to do with incompatibility with some other plugin, possibly blocking this request or potential caching issue.
Bruno Kos
June 28, 2019 at 12:20 pm #4107291
MCL van den
Hi Bruno,
I've tried what you said and it makes no difference.
June 28, 2019 at 1:01 pm #4107535
Bruno Kos
Can I ask you the following then? In order to debug this issue , can you install Duplicator plugin and create package so that I can try this on my localhost and possibly escalate further to 2nd tier?
https://wpml.org/faq/provide-supporters-copy-site/
Let me know if this is OK with you.
If yes, I will need WordPress admin username and password so I could download those packages. I have marked your next reply private so you can safely add this information.
Please make a full backup of your site before sharing this info!
Bruno Kos
July 1, 2019 at 6:05 am #4115705
MCL van den
Hi Bruno,
Did you get the package?
July 1, 2019 at 6:29 am #4115825
Bruno Kos
I apologize for not responding earlier - I wasn't working during the weekend. As for the issue, can you tell me the following:
- for which tag (at least one) this isn't working?
- Is the problem that tag is not showing to be translated here?
or here:
For example, this one:
- restauratie
In the WooCommerce multilingual panel, it does not seem to be translated. However, when I open it on the WooCommerce product tag section, I can in fact see the translation. However, there is something else I have noticed - when trying to deploy Duplicator package on my localhost, I received this:
DATABASE RESULTS
**ERROR** Query size limit [length=1048576] [sql=...]
DB VIEWS:	enabled
DB PROCEDURES:	enabled
ERRORS FOUND:	1
DROPPED TABLES:	0
RENAMED TABLES:	0
QUERIES RAN:	557313
I suspect that the issue has something to do with this:
https://stackoverflow.com/questions/8062496/how-to-change-max-allowed-packet-size
So on my localhost installation, I changed this to 512MB, but I am unable to confirm if this has really resolved the issue or not. That's why I need information on one (of few) tags that weren't translated before you created Duplicator package.
Bruno Kos
July 1, 2019 at 9:48 am #4117417
MCL van den
It's on the hidden link page that it isn't showing that a tag is translated.
You can test one on the last page called "zelfmoord deuren" what translates into "suicide doors".
July 1, 2019 at 10:50 am #4117901
Bruno Kos
Have a look at these images - this is what I see and the results are somewhat inconclusive. The thing I would like to bring to our 2nd tier is the fact that WooCommerce multilingual does not recognize tags being translated, even though WooCommerce Tags show that they are translated and I can in fact access these pages directly.
Unless you think there's something else I should report? Perhaps using tools such as hidden link would help me narrow down the issue and to know exactly the issue you're facing or more specifically, which of these issues should I report.
Bruno Kos
July 3, 2019 at 1:56 pm #4137137
MCL van den
Hi Bruno,
You've hit the nail on the head with the first paragraph.
July 4, 2019 at 7:14 am #4140647
Bruno Kos
Can you do this? Set this in wp-config.php:
Let me know if it works for you.
Bruno Kos
July 4, 2019 at 7:43 am #4140851
MCL van den
Hi Bruno,
That seems to work. Thanks.
July 4, 2019 at 8:00 am #4140989
Bruno Kos
Great - marking this as resolved!
Bruno Kos
