Last updated by Carlos Rojas 9 months, 2 weeks ago.
August 12, 2019 at 9:03 am #4379465
mofrehL
I am trying to: WooCommerce multilingual status
I expected to see: my status in woocommerce
Instead, I got: The site is experiencing technical difficulties. Please check your site admin email inbox for instructions.
August 12, 2019 at 3:31 pm #4381873
Carlos Rojas
I would like to ask you to follow this steps in order to isolate the cause of the issue:
- Back up your site first before making any change, this is for security reasons.
- Update all outdated plugins and themes.
- Flush any cache memory that might exists.
- Deactivate all the plugins that are not related to WPML.
- Switch for a moment to a WordPress default theme like Twenty Seventeen.
- If the issue is gone, activate one by one to see with which one there is an interaction issue.
Could you tell me the result of this steps?
Kind regards,
Carlos
August 12, 2019 at 5:17 pm #4382711
mofrehL
Hi!
I used another way by setting RT. After that I managed to log to my WooCommerce Status. There, I found that I missed translating one page of my store for a new language I latter added
August 12, 2019 at 8:34 pm #4383549
Carlos Rojas
I understand that the issue is solved. Is this correct?
Carlos
August 15, 2019 at 3:58 pm #4402291
mofrehL
August 15, 2019 at 5:41 pm #4402781
Carlos Rojas
I'm glad to hear that the issue is solved 🙂
Please don't hesitate to contact us if you need our help in the future with WPML. We will be more than happy to help.
Carlos
