Our next available supporter will start replying to tickets in about 10.31 hours from now. Thank you for your understanding.
This topic contains 27 replies, has 5 voices.
Last updated by David 6 years, 4 months ago.
Assigned support staff: David.
April 11, 2013 at 3:13 pm #118603
Dimitri
FYI: similar problem on this Threat
http://wpml.org/forums/topic/variations-translation-crash-woocommerce/
Dimitri
April 12, 2013 at 10:23 am #118806
David
Dear Dimitri
I have been reviewing your Dashboard and this is what I found:
The translations for the values of the Color attribute are properly linked with each other and these variations should be sync'd properly.
But the values for sizes are loose, they are created but not linked with each other, so here the sync will fail.
Can you link these values before we do any more testing? I have attached screenshots.
David
April 12, 2013 at 10:25 am #118808
David
To link a translation to its original, edit the translation and select the correct value in "This is a translation of".
April 12, 2013 at 12:22 pm #118857
Dimitri
OK, i've re-linked all products variations.
I've made a new test translating a product in English (main language = French).
Variations are still not correctly linked to variations in main language. See Attached print screen.
Dimitri
April 13, 2013 at 8:27 am #119004
Dimitri
I tried WCML 2.2 and unfortunately it still do not work correctly
Do you think there is any hope that WCML works correctly soon ?
Dimitri
April 15, 2013 at 11:58 am #119354
Dimitri
Any hope to get a solution this week ?
April 15, 2013 at 4:18 pm #119446
David
Dear Dimitri,
Im right now looking into your server, I will get back to you in a little while.
David
April 15, 2013 at 5:41 pm #119466
David
Dear Dimitri,
Ive been able to reproduce your issue on my localhost, which gives me the chance to debug properly. I will have a solution for you tomorrow during the morning.
Best,
David
April 16, 2013 at 12:17 pm #119708
David
Dear Dimitri,
I thought I had reproduced the problem last night but today its working perfectly on my localhost. I have compared version numbers, downloaded your dump with no luck. I need to reproduce the error local to be able to properly debug and fix it.
I see two way of doing this:
1) I can setup a test server where we try to replicate the issue.
2) You can also send me your themes and plugins to try and replicate your scenario exactly.
Let me know what you prefer and I will try to resolve this asap.
Best
David
April 16, 2013 at 12:25 pm #119711
Dimitri
Read your email: I've send you a link to a backup (files and mysql dump).
Hope you can do it fast.
Very very urgent for me.
Dimitri
April 16, 2013 at 2:45 pm #119768
David
I replicated your install and everything works fine. I sent you access details for you to test too.
The only difference may PHP version or MySQL version.
Lets see if we reach the bottom of this.
Best,
David
April 16, 2013 at 3:17 pm #119780
Dimitri
DavidGW tried with my files and my sql dump and everything was working great for him without any changes.
I optimized all my SQL tables with phpmyadmin and the issue seems to be resolved 🙂
I'm still testing.
Have a try and share.
April 16, 2013 at 4:02 pm #119797
David
Good find. I would never of thought.
Keep me posted on your progress.
Best,
David
The topic ‘[Closed] Woocommerce variable product translations do not work correctly’ is closed to new replies.
