Last updated by Irene 5 years, 10 months ago.
Assigned support staff: Andreas Neuber.
August 26, 2013 at 9:29 am #157557
Irene
I'm using Wooslider Products Slideshow in combination with Wooslider to display products on my homepage.
It works fine in German.
In the translated English version, however, when I try to insert the slider via "add media", it shows me the German categories instead of the English categories to select.
At one point, I had a selection of English categories, but it only showed me an empty frame.
What I've tried so far:
- de-activate and re-activate the plugins
- "set languages" on the troubleshooting page
To no avail.
Categories are all translated and mapped.
Can you help?
Thank you!
August 26, 2013 at 10:38 am #157587
Andreas Neuber
Hello Irene,
This sounds like a "plugin/WPML incompatibility". WPML and Woocommerce are working nicely together but sometimes there are problems with add-on plugins.
In order to say more, could you provide us with credentials for your website and we have a closer look?
I will sent you an email with more details in a minute. Thanks in advance!
August 28, 2013 at 10:29 am #158361
Andreas Neuber
Hello Irene,
Thanks for the login info!
We are checking right now, but must admit I have my difficulties.
Just to make sure that I'm not looking at the wrong spot, in case you like to add a new "product slide" under which WP admin menu point would you do it?
August 28, 2013 at 12:00 pm #158404
Irene
Hi Andreas,
thanks for getting back to me. The WooSlider is the one in the image attached.
However, if you want to use it as a products slider, you just go inside Startseite / Homepage (en) and insert it there.
The woo slider is inserted from the Insert Media menu. (see second screenshot).
Please make sure you're in the right backend: tswisst.de (not shop.tswisst.de)
HTH!
August 29, 2013 at 11:28 am #158807
Andreas Neuber
Hello Irene,
Thanks for the feedback - good that I asked 🙂
Could you try this:
> go to hidden link
> and adjust the shortcode to:
[wooslider category="rolex-parts,vintage-watches" slider_type="products" layout="text-right" overlay="none" id="start" link_title_to_product="true"]
Basically, different id="". Instead of "Home" - "start".
Does the slider appear then?
August 29, 2013 at 12:11 pm #158833
Irene
Hi Andreas,
thanks a bunch!
Didn't work with the code, but changing the id="" put me on the right track.
- I created a new slide under "Add slides" instead of going through the Add media screen directly in the home page
- then took that shortcode and inserted it in the English home page!
Thanks again for your help, saved me a few grey hairs!
/Irene
