Problem: After theme updated I lost all the custom CSS in the style.cs file
Solution: Apply the custom CSS to Appearance -> Customize -> Additional CSS.
Relevant Documentation:
Last updated by Carlos Rojas 2 years, 2 months ago.
May 27, 2018 at 2:40 pm #2235098
fulvioP
https://wpml.org/forums/topic/wp-bakery-carousel-visualization-problem/
That's the previous problem solved by Carlos, now again don't work as you can see for example in this page : hidden link
Let me know thank you
May 29, 2018 at 4:41 pm #2247314
Carlos Rojas
I'm sorry, I just saw that you posted another comment in the previous ticket.
I tried to log in the site but the credentials provided in the previous ticket didn't work. I have set your next answer private, there you will find the correspondent fields for the credentials (wp-admin and FTP).
This way I can take another look at the site.
Note: Could you tell me if you updated the theme?
Carlos
May 30, 2018 at 5:47 pm #2252736
Carlos Rojas
I applied the CSS to Appearance -> Customize -> Additional CSS.
Could you confirm that the issue is solved?
Carlos
May 31, 2018 at 6:54 pm #2258191
fulvioP
Yes is ok again!
But tell me you suggest to stop the updates?
Thank you!
May 31, 2018 at 7:04 pm #2258278
Carlos Rojas
I'm glad that the ticket is solved!
Regarding the updates. The CSS I added the for the previous ticket was in the style.css file that was rewriten when you updated the theme. I recommend you to create a child theme so you can preserve all changes made to the theme after the updates. In this link you will find more information regarding this subject: https://codex.wordpress.org/Child_Themes
Carlos
