Problem: I am trying to have a correct visualization of a translated carousel.
Solution: Add the custom CSS to the style.css file so it can be loaded for all languages.
Relevant Documentation:
Last updated by fulvioP 2 years, 1 month ago.
May 11, 2018 at 10:01 am #2085712
fulvioP
I expected to see ike this : hidden link
Instead, I got: The carousel work but I dont see corners and arrows of the translated carousel.
Please check it
May 11, 2018 at 5:11 pm #2092968
Carlos Rojas
The cause of this issue is that some CSS code is not loading for the secondary language. In order to solve this issue you need to use the lang pseudo selector in the CSS. In this link you will find more information regarding this pseudo selector: hidden link
I also recommend you to add this CSS to the styel.css file instead of doing it in a custom CSS area.
Kind regards,
Carlos
May 12, 2018 at 6:22 am #2096203
fulvioP
Hello Carlos,
can you write where and what I need to put to make the translation working please?
Thank you
May 14, 2018 at 7:55 am #2112414
fulvioP
can you help me please ?
May 14, 2018 at 11:47 am #2118103
Carlos Rojas
Our Debugging Procedures
Carlos
May 14, 2018 at 4:02 pm #2124264
Carlos Rojas
I added the CSS code for the carousel to the style.css file. Please check the page and let me know if the issue is solved.
Carlos
May 14, 2018 at 4:07 pm #2124301
fulvioP
no you can check the carousel in this page :
let me know.
Thank you
May 14, 2018 at 4:50 pm #2124826
Carlos Rojas
I added the missing CSS code to the style.css file. Please check again the carousel and let me know if the issue is solved.
Note: Please flush the cache in your browser side by using Ctrl+F5 or Cmd+F5 in your browser. You can also visit the site in incognito mode.
Carlos
May 15, 2018 at 9:00 am #2132492
fulvioP
Thank you Carlos for your support.
Now it works !
May 15, 2018 at 12:20 pm #2138489
Carlos Rojas
I'm glad to hear that the issue is solved 🙂
Please don't hesitate to contact us if you need our help in the future with WPML. We will be more than happy to help.
Carlos
May 21, 2018 at 9:24 am #2200070
fulvioP
Hello
Sorry but I see the same problem also in other page from my mobile like this one:
Can you check please?
