Problem: I want to translate WP Front Notification popup and buttons/links
Solution: currently, WP Front Notification isn't fully compatible with WPML but you can tweak the code to translate the popup and the buttons. See the 2 links below, in the first one you can find instruction for the popup, in the second for the buttons
Relevant Documentation: https://wpml.org/forums/topic/translation-of-wpfront-notification-bar-plugin/ https://wpml.org/forums/topic/wp-front-notification-not-translatable/#post-3640699
Last updated by julianZ-4 2 years, 7 months ago.
April 16, 2019 at 2:23 pm #3622923
julianZ-4
I am trying to: Use WP Front Notifications in more than one language
I expected to see: That I be able to translate WP Front Notification in String translation, that did not work.
Instead, I got: Always the not translated text.
I already found this support thread: https://wpml.org/forums/topic/translation-of-wpfront-notification-bar-plugin/
I used that solution to be able to translate the notification text. That worked. But I also would like to translate the button-text and button-url.
Can you please help and tell me which changes I need to make?
April 17, 2019 at 1:25 pm #3631163
Laura
thanks for contacting us.
Probably you'll need to add the other texts you need to register them as well in the xml-config file.
To do that, you have first to find their name.
Please do as it follows:
- go to WPML -> String Translation
- go to the string admin page (link at the bottom of the page)
- open the source code (CTRL+U)
- search for the texts you need to translate
- probably they're under the domain "wpfront-notification-bar-options"
- once you've find them, add them to the xml-config file; if they're under "wpfront-notification-bar-options" you will only need to add
 <key name="youroptionname" />
, otherwise you'll need to add a key name too.
For more information, please look at this: https://wpml.org/documentation/support/language-configuration-files/#admin-texts
Let me know if this helps you or if you need further assistance.
April 17, 2019 at 4:14 pm #3632637
julianZ-4
Thanks Laura. I did that, but I think the step with the edit of the template.php file of the tutorial is missing. So no change at the moment - I see these variables under String Translations. They are translated. But in the frontend, it always shows the original language.
Can you please tell me what I have to change in the template.php of the plugin? I tried myself without luck..
This is my new config xml:
<wpml-config>
    <admin-texts>
        <key name="wpfront-notification-bar-options">
            <key name="message" />
            <key name="button_action_url" />
            <key name="button_text" />
        </key>
    </admin-texts>
</wpml-config>
April 18, 2019 at 3:49 pm #3640511
Laura
please try to add 2 snippet like this one (you should already have added it)
<?php
    echo apply_filters( 'wpml_translate_single_string', $this->options->message(), 'admin_texts_wpfront-notification-bar-options', '[wpfront-notification-bar-options]KEYNAME', apply_filters( 'wpml_current_language', NULL ) );
just change KEYNAME with the new keys you registered.
April 18, 2019 at 3:54 pm #3640521
julianZ-4
Hi Laura
It seems to be a different format.
Please find the contents of the notification-bar-template.php here:
<?php
  WPFront Notification Bar Plugin
  Copyright (C) 2013, WPFront.com
  Website: wpfront.com
  Contact: syam@wpfront.com
  WPFront Notification Bar Plugin is distributed under the GNU General Public License, Version 3,
  June 2007. Copyright (C) 2007 Free Software Foundation, Inc., 51 Franklin
  St, Fifth Floor, Boston, MA 02110, USA
  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
  ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
  WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
  ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
  (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
  LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
  ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
  SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 * Template for WPFront Notification Bar
 * @author Syam Mohan <syam@wpfront.com>
 * @copyright 2013 WPFront.com
<style type="text/css">
    #wpfront-notification-bar
        background: <?php echo $this->options->bar_from_color(); ?>;
        background: -moz-linear-gradient(top, <?php echo $this->options->bar_from_color(); ?> 0%, <?php echo $this->options->bar_to_color(); ?> 100%);
        background: -webkit-gradient(linear, left top, left bottom, color-stop(0%,<?php echo $this->options->bar_from_color(); ?>), color-stop(100%,<?php echo $this->options->bar_to_color(); ?>));
        background: -webkit-linear-gradient(top, <?php echo $this->options->bar_from_color(); ?> 0%,<?php echo $this->options->bar_to_color(); ?> 100%);
        background: -o-linear-gradient(top, <?php echo $this->options->bar_from_color(); ?> 0%,<?php echo $this->options->bar_to_color(); ?> 100%);
        background: -ms-linear-gradient(top, <?php echo $this->options->bar_from_color(); ?> 0%,<?php echo $this->options->bar_to_color(); ?> 100%);
        background: linear-gradient(to bottom, <?php echo $this->options->bar_from_color(); ?> 0%, <?php echo $this->options->bar_to_color(); ?> 100%);
        filter: progid:DXImageTransform.Microsoft.gradient( startColorstr='<?php echo $this->options->bar_from_color(); ?>', endColorstr='<?php echo $this->options->bar_to_color(); ?>',GradientType=0 );
    #wpfront-notification-bar div.wpfront-message
        color: <?php echo $this->options->message_color(); ?>;
    #wpfront-notification-bar a.wpfront-button
        background: <?php echo $this->options->button_from_color(); ?>;
        background: -moz-linear-gradient(top, <?php echo $this->options->button_from_color(); ?> 0%, <?php echo $this->options->button_to_color(); ?> 100%);
        background: -webkit-gradient(linear, left top, left bottom, color-stop(0%,<?php echo $this->options->button_from_color(); ?>), color-stop(100%,<?php echo $this->options->button_to_color(); ?>));
        background: -webkit-linear-gradient(top, <?php echo $this->options->button_from_color(); ?> 0%,<?php echo $this->options->button_to_color(); ?> 100%);
        background: -o-linear-gradient(top, <?php echo $this->options->button_from_color(); ?> 0%,<?php echo $this->options->button_to_color(); ?> 100%);
        background: -ms-linear-gradient(top, <?php echo $this->options->button_from_color(); ?> 0%,<?php echo $this->options->button_to_color(); ?> 100%);
        background: linear-gradient(to bottom, <?php echo $this->options->button_from_color(); ?> 0%, <?php echo $this->options->button_to_color(); ?> 100%);
        filter: progid:DXImageTransform.Microsoft.gradient( startColorstr='<?php echo $this->options->button_from_color(); ?>', endColorstr='<?php echo $this->options->button_to_color(); ?>',GradientType=0 );
        color: <?php echo $this->options->button_text_color(); ?>;
    #wpfront-notification-bar-open-button
        background-color: <?php echo $this->options->open_button_color(); ?>;
    #wpfront-notification-bar  div.wpfront-close
        border: 1px solid <?php echo $this->options->close_button_color(); ?>;
        background-color: <?php echo $this->options->close_button_color(); ?>;
        color: <?php echo $this->options->close_button_color_x(); ?>;
    #wpfront-notification-bar  div.wpfront-close:hover
        border: 1px solid <?php echo $this->options->close_button_color_hover(); ?>;
        background-color: <?php echo $this->options->close_button_color_hover(); ?>;
</style>
<?php if ($this->options->display_button() && $this->options->button_action() == 2) { ?>
    <script type="text/javascript">
        function wpfront_notification_bar_button_action_script() {
            try {
    <?php echo $this->options->button_action_javascript(); ?>
            catch (err) {
    </script>
<?php } ?>
<div id="wpfront-notification-bar-spacer"  style="display: none;">
    <div id="wpfront-notification-bar-open-button" class="<?php echo $this->options->position() == 1 ? 'top wpfront-bottom-shadow' : 'bottom wpfront-top-shadow'; ?>"></div>
    <div id="wpfront-notification-bar" class="wpfront-fixed <?php if ($this->options->display_shadow()) echo $this->options->position() == 1 ? 'wpfront-bottom-shadow' : 'wpfront-top-shadow'; ?>">
        <?php if ($this->options->close_button()) { ?>
            <div class="wpfront-close">X</div>
        <?php } ?>
        <table border="0" cellspacing="0" cellpadding="0">
            <tr>
                <td>
<div class="wpfront-message">
<?php
    echo apply_filters( 'wpml_translate_single_string', $this->options->message(), 'admin_texts_wpfront-notification-bar-options', '[wpfront-notification-bar-options]message', apply_filters( 'wpml_current_language', NULL ) );
</div>
                    <div>
                        <?php
                            if ($this->options->display_button()) {
                                $button_text = $this->get_button_text();
                                <?php if ($this->options->button_action() == 1) { ?>
                                    <a class="wpfront-button" href="<?php echo $this->options->button_action_url(); ?>"  target="<?php echo $this->options->button_action_new_tab() ? '_blank' : '_self'; ?>" <?php echo $this->options->button_action_url_nofollow() ? 'rel="nofollow"' : ''; ?>><?php echo $button_text; ?></a>
                                <?php } ?>
                                <?php if ($this->options->button_action() == 2) { ?>
                                    <a class="wpfront-button" onclick="javascript:wpfront_notification_bar_button_action_script();"><?php echo $button_text; ?></a>
                                <?php } ?>
                        <?php } ?>
                    </div>
                </td>
            </tr>
        </table>
    </div>
</div>
<?php echo $this->options->custom_css(); ?>
</style>
Can you please tell me where to change what?
April 18, 2019 at 4:11 pm #3640699
julianZ-4
For everyone who wants to know how:
<?php
</style>
            try {
            catch (err) {
    </script>
<?php } ?>
        <?php } ?>
            <tr>
                <td>
<?php
</div>
                    <div>
                        <?php
                                $button_text = apply_filters( 'wpml_translate_single_string', $this->get_button_text(), 'admin_texts_wpfront-notification-bar-options', '[wpfront-notification-bar-options]button_text', apply_filters( 'wpml_current_language', NULL ) );
                                    <a class="wpfront-button" href="<?php echo apply_filters( 'wpml_translate_single_string', $this->options->button_action_url(), 'admin_texts_wpfront-notification-bar-options', '[wpfront-notification-bar-options]button_action_url', apply_filters( 'wpml_current_language', NULL ) );
                                <?php } ?>
                                <?php } ?>
                        <?php } ?>
                    </div>
                </td>
            </tr>
        </table>
    </div>
</div>
</style>
