This topic contains 34 replies, has 2 voices.
Last updated by Carlos Rojas 1 month ago.
November 26, 2019 at 1:05 pm #5021673
mantasV-2
Yesterday we had ticket with WPL PRO addon in single property area, which are not translating some strings, but they're all translated corectly.
November 27, 2019 at 11:22 am #5028461
Carlos Rojas
Thank you for opening a new ticket.
Could you provide the access credentials again? The ones you provided in the previous ticket were automatically removed after the ticket was set to resolved.
I have set your next answer private so you can provide the credentials in a secure way.
Carlos
December 2, 2019 at 11:37 am #5052951
Carlos Rojas
I kindly ask you to update all outdated plugins and themes, specially WPML plugins, to their latest version. Flush any cache memory that might exists and double check if the issue persists.
Could you tell me if the issue persists?
Carlos
December 3, 2019 at 7:23 am #5057929
mantasV-2
very strange. Website are gone. When i try to enter dzukas.lt website popup ask me to download file.
December 3, 2019 at 8:08 am #5058169
mantasV-2
ok, just done all updates, nothing changed.
December 3, 2019 at 3:57 pm #5062605
Carlos Rojas
Thank you for your feedback.
I would like to ask your authorization to make a copy of the site in order to escalate it to our 2nd tier of support.
Carlos
December 9, 2019 at 8:03 am #5090505
mantasV-2
Ok, go ahead 🙂
December 9, 2019 at 9:19 am #5091029
Carlos Rojas
Thank you very much for your authorization.
I already created the Duplicator package, but just before escalate this issue I would like to ask you to apply this errata and let me know if the issue is solved in the site: https://wpml.org/errata/in-some-cases-some-strings-are-not-translating-properly/
Carlos
December 10, 2019 at 9:56 am #5098177
mantasV-2
Hi, now everything works fine.
But when i go to single property, cant switch between languages. How to fix that?
December 10, 2019 at 10:50 am #5098811
Carlos Rojas
I tried to access the site but it seems the credentials changed. Could you double check the credentials and edit the private message if necessary?
Carlos
December 10, 2019 at 11:03 am #5098909
mantasV-2
Done, So we dont need WPL plugin support? I can cancel theyre research.
December 10, 2019 at 11:29 am #5099321
Carlos Rojas
Could you describe the steps you followed to translate the properties?
Carlos
December 10, 2019 at 1:07 pm #5100049
mantasV-2
These steps, but not sure. Jus deleted 1 string called "APRAŠYMAS", and they all appeared again. Can we leave this topic opened for a week?
December 10, 2019 at 1:26 pm #5100265
mantasV-2
Same again 🙂 was fixed for couple of hours 😉
December 10, 2019 at 10:45 pm #5103143
Carlos Rojas
I asked the steps you follow to translate the properties because I visit the site and I can see that the properties now appear only in Lithuanian and not in Russian. Did you removed the Russian version of the properties?
Carlos
