This topic contains 9 replies, has 6 voices.
Last updated by Andrey 6 years ago.
Assigned support staff: Andrey.
June 16, 2015 at 8:17 am #639202
Andrey
Timezone: Europe/Kiev (GMT+02:00)
After rescanning the strings using the version WPML 3.2.x some of you may see that all your strings need to be translated again. Do not worry, we are working on this to get things back to normal. Your data is not lost. Please do not rescan and do not try to fix this by yourself. This will be solved in our new release which will come soon.
June 16, 2015 at 11:04 am #639429
tannW
How do we re-enable the disabled translations in the mean time?
June 16, 2015 at 11:46 am #639462
sintonia
I also urgent need to reactivate strings disabled in the meantime. how can I do?
June 16, 2015 at 1:02 pm #639567
dragosS
I have a problem with string translations after re scanning in version 3.2.X - they are not translating anymore. The default language was Romanian and translation English - now the string translation states Romanian.
The option for the original string language is not showing on string translation section
June 16, 2015 at 1:48 pm #639621
Andrey
We are working on this, need to wait a little bit. I'll update here when an update is ready.
June 16, 2015 at 3:00 pm #639707
mihovilM
Hey Andrey,
Can you please tell us if there is any harm done if we rescanned the strings already? As I can see, my string translations are still on the list, they are just marked as removed.
Thank you!
June 16, 2015 at 8:45 pm #639978
xavierC-7
If you could also fix the woocommerce shop showing "No products were found matching your selection." on main language, i can't be the only one having this... since 3.2
June 17, 2015 at 5:43 am #640069
Andrey
@xavierc-7, we are investigating this, please wait for a reply in your ticket.
We have released WPML 3.2.2 which solves the problem with string translation contexts. With this version of WPML plugin the problem should go away.
You can check the latest released versions under "My Account -> Downloads" on this site. Instructions to update can be found here: http://wpml.org/faq/install-wpml/ >> manual
Make sure to update all needed components.
Please remember to backup your database first before you proceed!
June 17, 2015 at 8:15 am #640207
dragosS
I have updated to 3.2.2 and all the other plugins. The problem is not solved,
On the Romanian section it shows part Romanian part English translations, on the English section the same. It does not matter what is the default language setting.
On the string translations the translation language now is Romanian and was English.
There is no option to change the original string Language.
June 17, 2015 at 9:08 am #640270
Andrey
@dragoss, It looks like you got something different, not the issue which was described initially. In order to ensure that your problem gets the attention it deserves, please open a new ticket detailing your issue.
I am closing this ticket, it is fixed now in version 3.2.2 of WPML plugin and shouldn't be a problem.
If someone still has related issue, please open a new ticket.
