This topic contains 5 replies, has 1 voice.
Last updated by Vincent Dagenais 3 weeks, 5 days ago.
March 19, 2026 at 4:48 pm #17911973
Vincent Dagenais
I have WPML, WooCommerce, WooCommerce multilingual, ACF and ACF Multilingual.
When I activate ACF Multilingual, in the backend , all single post pages (products/orders) get broken. And look something like that.
When I deactivated only WPML ACF Multilingual, the error disapears.
March 19, 2026 at 5:04 pm #17912039
Vincent Dagenais
I did finally refresh the page, and the plugin is up to date but the error in product or order page is still broken
March 19, 2026 at 5:09 pm #17912057
Vincent Dagenais
I do have a local and stage environnement for this site. Local and stage i do not have the same issue. And my local and stage site has the same outdated plugin as in the wpml support debug information.
March 21, 2026 at 5:21 pm #17915897
I'd be happy to take a closer look at this, but the problem is that to investigate the issue, we need to switch the theme and disable plugins, which is not recommended to do on a production site.
Is your staging site a fresh copy of the current site?
I'd like to request temporary access (wp-admin and FTP) to the production website to investigate the issue further. I might try to take my own local copy and see if I can replicate the issue.
You'll find the necessary fields below the comment section if you log in to leave the next reply. The information you provide will be private, meaning only you and I will be able to see and access it.
IMPORTANT
Please be sure to create a backup of the website and database before granting us access.
If you don't see the "wp-admin / FTP" fields, your login credentials for the post and website will be set to "PUBLIC." Do NOT publish the information unless you see the required wp-admin / FTP fields.
When replying again, click "I still need assistance".
Video:
Please note that we are required to request this information individually on each ticket. We are not permitted to access any login information that was not specifically provided in the private reply form for this ticket.
March 26, 2026 at 12:41 pm #17928987
Vincent Dagenais
Hi Andreas,
I will need 1 day to make a backup and make it run on a another environnement. We do have a stage site, but the stage site is working well.
When I do get the stage site up and running, I'll post in the priovate section the credentials.
Also I see that something in the acf html section, the html gets broken and the main product content gets rendered inside the element i with class dashicons.
Good news I was able to reproduce the problem :
WPML, WooCommerce, ACF, WPML WooCommerce, WPML ACF, and a acf json file with repeater and custom fields associated with a product.
How could I send you the json file?
Here is the json file minified :
[{"key":"group_5ad8eb22b5d12","title":"Contenu de page","fields":[{"key":"field_5ad8eb46109e4","label":"Contenu de page","name":"page_content","aria-label":"","type":"flexible_content","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"layouts":{"5ad8ec03f3812":{"key":"5ad8ec03f3812","name":"leading_content","label":"Introduction","display":"block","sub_fields":[{"key":"field_5b2a9977d614e","label":"Contenu","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5ad8ed05649b8","label":"Contenu","name":"content","aria-label":"","type":"wysiwyg","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","tabs":"all","toolbar":"full","media_upload":1,"delay":0},{"key":"field_5b2a9959d614d","label":"<i class=\"dashicons dashicons-admin-generic\"/>","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5ad8ed15649b9","label":"Affichage","name":"layout","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"container":"Conteneur","fluid":"Fluide"},"allow_null":0,"default_value":"container","layout":"horizontal","return_format":"value"},{"key":"field_5b2a9ab1aa056","label":"Marges","name":"content_spacing","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"margin":"Marges","nomargin":"Aucune"},"allow_null":0,"default_value":"margin","layout":"horizontal","return_format":"value"},{"key":"field_5b2a99a4d614f","label":"ID","name":"block_id","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5b2a99b2d6150","label":"Classe","name":"block_class","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""}],"min":"","max":""},"5af1e8c3f4c3b":{"key":"5af1e8c3f4c3b","name":"heading_content","label":"Entête","display":"block","sub_fields":[{"key":"field_5b2a9da7bc464","label":"Contenu","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5af1e8ecf4c3c","label":"Titre","name":"title","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5af1e911f4c3d","label":"Sous-titre","name":"subtitle","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5b2a9d5abc461","label":"<i class=\"dashicons dashicons-admin-generic\"/>","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5af1e938f4c3e","label":"Affichage","name":"layout","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"container":"Conteneur","fluid":"Fluide"},"allow_null":0,"default_value":"container","layout":"horizontal","return_format":"value"},{"key":"field_5b2a9f39e6d49","label":"Marges","name":"content_spacing","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"margin":"Marges","nomargin":"Aucune"},"allow_null":0,"default_value":"margin","layout":"horizontal","return_format":"value"},{"key":"field_5af1e96ff4c3f","label":"Position du contenu","name":"position","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"left":"<i class=\"dashicons dashicons-editor-alignleft\"/>","center":"<i class=\"dashicons dashicons-editor-aligncenter\"/>","right":"<i class=\"dashicons dashicons-editor-alignright\"/>"},"allow_null":0,"default_value":"left","layout":"horizontal","return_format":"value"},{"key":"field_5b2a9d87bc462","label":"ID","name":"block_id","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5b2a9d95bc463","label":"Classe","name":"block_class","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""}],"min":"","max":""},"5af056b8cb678":{"key":"5af056b8cb678","name":"call_to_action_content","label":"Appel à l'action","display":"block","sub_fields":[{"key":"field_5b2aa006f2872","label":"Contenu","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5af05734cb679","label":"Titre","name":"title","aria-label":"","type":"text","instructions":"","required":1,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5af0573dcb67a","label":"Contenu","name":"content","aria-label":"","type":"textarea","instructions":"","required":1,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","maxlength":"","rows":"","new_lines":""},{"key":"field_5af05829cb67d","label":"Lien","name":"link","aria-label":"","type":"link","instructions":"","required":1,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"return_format":"array"},{"key":"field_5af05775cb67b","label":"Icône","name":"icon","aria-label":"","type":"file","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"50","class":"","id":""},"return_format":"array","library":"all","min_size":"","max_size":"","mime_types":""},{"key":"field_5af05800cb67c","label":"Image d'arrière plan","name":"bg_img","aria-label":"","type":"file","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"50","class":"","id":""},"return_format":"array","library":"all","min_size":"","max_size":"","mime_types":""},{"key":"field_5b2a9ff7f2871","label":"<i class=\"dashicons dashicons-admin-generic\"/>","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5af0587fcb67f","label":"Affichage","name":"layout","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"container":"Conteneur","fluid":"Fluide"},"allow_null":0,"default_value":"fluid","layout":"horizontal","return_format":"value"},{"key":"field_5b2aa39443807","label":"Marges","name":"content_spacing","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"margin":"Marges","nomargin":"Aucune"},"allow_null":0,"default_value":"margin","layout":"horizontal","return_format":"value"},{"key":"field_5af05848cb67e","label":"Position du contenu","name":"position","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"left":"<i class=\"dashicons dashicons-editor-alignleft\"/>","right":"<i class=\"dashicons dashicons-editor-alignright\"/>"},"allow_null":0,"default_value":"left","layout":"horizontal","return_format":"value"},{"key":"field_5b2aa33217702","label":"ID","name":"block_id","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5b2aa33b17703","label":"Classe","name":"block_class","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""}],"min":"","max":""},"5af311cd5397e":{"key":"5af311cd5397e","name":"two_cols_content","label":"Deux colonnes","display":"block","sub_fields":[{"key":"field_5b2aa5a5d5629","label":"Contenu","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5af3125e53981","label":"Titre","name":"title","aria-label":"","type":"text","instructions":"","required":1,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5af3128153982","label":"Contenu","name":"content","aria-label":"","type":"wysiwyg","instructions":"","required":1,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","tabs":"all","toolbar":"full","media_upload":1,"delay":0},{"key":"field_5af3129253983","label":"Bouton","name":"btn","aria-label":"","type":"group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"layout":"block","sub_fields":[{"key":"field_5af312e3b00c3","label":"Lien","name":"link","aria-label":"","type":"link","instructions":"","required":1,"conditional_logic":0,"wrapper":{"width":"50","class":"","id":""},"return_format":"array"},{"key":"field_5b2bbf7d1603d","label":"Préfixe","name":"prefix","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":4},{"key":"field_5af312f5b00c4","label":"Icône","name":"icon","aria-label":"","type":"text","instructions":"ex: fa-phone","required":0,"conditional_logic":0,"wrapper":{"width":"50","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""}]},{"key":"field_5af3131fb00c5","label":"Galerie","name":"gallery","aria-label":"","type":"gallery","instructions":"","required":1,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"min":1,"max":"","insert":"append","library":"all","min_width":"","min_height":"","min_size":"","max_width":"","max_height":"","max_size":"","mime_types":"","return_format":"array","preview_size":"medium"},{"key":"field_5b2aa5bdd562a","label":"<i class=\"dashicons dashicons-admin-generic\"/>","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5af311df5397f","label":"Affichage","name":"layout","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"container":"Conteneur","fluid":"Fluide"},"allow_null":0,"default_value":"container","layout":"horizontal","return_format":"value"},{"key":"field_5b2aa602d562b","label":"Marges","name":"content_spacing","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"margin":"Marges","nomargin":"Aucune"},"allow_null":0,"default_value":"margin","layout":"horizontal","return_format":"value"},{"key":"field_5af4a2f976902","label":"Proportion","name":"size","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"25":"1/4","33":"1/3","50":"1/2"},"allow_null":0,"default_value":50,"layout":"horizontal","return_format":"value"},{"key":"field_5af3121c53980","label":"Direction","name":"direction","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"row":"<i class=\"dashicons dashicons-editor-alignleft\"/>","row-reverse":"<i class=\"dashicons dashicons-editor-alignright\"/>"},"allow_null":0,"default_value":"row","layout":"horizontal","return_format":"value"},{"key":"field_5af4a2a976901","label":"Disposition","name":"disposition","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"choices":{"standard":"Standard","hero":"Plein écran"},"allow_null":0,"default_value":"","layout":"horizontal","return_format":"value"},{"key":"field_5b2aa7abb93aa","label":"ID","name":"block_id","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5b2aa7bcb93ab","label":"Classe","name":"block_class","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""}],"min":"","max":""},"5af34979054bc":{"key":"5af34979054bc","name":"columns_content","label":"Multi-colonnes","display":"block","sub_fields":[{"key":"field_5b2aaa0d085a6","label":"Contenu","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5af34b7d054c0","label":"Colonnes","name":"columns_content_repeater","aria-label":"","type":"repeater","instructions":"","required":1,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"collapsed":"","min":1,"max":4,"layout":"row","button_label":"Ajouter un bloc","sub_fields":[{"key":"field_5af34be1b619d","label":"Contenu","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0,"parent_repeater":"field_5af34b7d054c0"},{"key":"field_5af34c23b619e","label":"Titre","name":"title","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":"","parent_repeater":"field_5af34b7d054c0"},{"key":"field_5af34c2eb619f","label":"Contenu","name":"content","aria-label":"","type":"wysiwyg","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","tabs":"all","toolbar":"full","media_upload":0,"delay":0,"parent_repeater":"field_5af34b7d054c0"},{"key":"field_5af34c4bb61a0","label":"Lien","name":"link","aria-label":"","type":"link","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"return_format":"array","parent_repeater":"field_5af34b7d054c0"},{"key":"field_5af34c7cb61a1","label":"Média","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0,"parent_repeater":"field_5af34b7d054c0"},{"key":"field_5af34c8db61a2","label":"Média","name":"media","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"choices":{"none":"Aucun","image":"Image","icon":"Icône"},"allow_null":0,"default_value":"none","layout":"horizontal","return_format":"value","parent_repeater":"field_5af34b7d054c0"},{"key":"field_5af34cdfb61a4","label":"Type d'icône","name":"type_icon","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":[[{"field":"field_5af34c8db61a2","operator":"==","value":"icon"}]],"wrapper":{"width":"","class":"","id":""},"choices":{"fontawesome":"Font Awesome","image":"Image"},"allow_null":0,"default_value":"fontawesome","layout":"horizontal","return_format":"value","parent_repeater":"field_5af34b7d054c0"},{"key":"field_5af34d60300bb","label":"Préfixe","name":"font_awesome_prefix","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":[[{"field":"field_5af34c8db61a2","operator":"==","value":"icon"},{"field":"field_5af34cdfb61a4","operator":"==","value":"fontawesome"}]],"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":4,"parent_repeater":"field_5af34b7d054c0"},{"key":"field_5af34da110d51","label":"Font awesome","name":"font_awesome","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":[[{"field":"field_5af34c8db61a2","operator":"==","value":"icon"},{"field":"field_5af34cdfb61a4","operator":"==","value":"fontawesome"}]],"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":"","parent_repeater":"field_5af34b7d054c0"},{"key":"field_5af34dc210d53","label":"Icône","name":"icon","aria-label":"","type":"image","instructions":"","required":0,"conditional_logic":[[{"field":"field_5af34c8db61a2","operator":"==","value":"icon"},{"field":"field_5af34cdfb61a4","operator":"==","value":"image"}]],"wrapper":{"width":"","class":"","id":""},"return_format":"array","preview_size":"thumbnail","library":"all","min_width":"","min_height":"","min_size":"","max_width":"","max_height":"","max_size":"","mime_types":"","parent_repeater":"field_5af34b7d054c0"},{"key":"field_5af34dee10d55","label":"Icône à côté du titre","name":"title_icon","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":[[{"field":"field_5af34c8db61a2","operator":"==","value":"icon"}]],"wrapper":{"width":"","class":"","id":""},"choices":{"no":"Non","yes":"Oui"},"allow_null":0,"default_value":"no","layout":"horizontal","return_format":"value","parent_repeater":"field_5af34b7d054c0"},{"key":"field_5af34cb3b61a3","label":"Image","name":"image","aria-label":"","type":"image","instructions":"","required":0,"conditional_logic":[[{"field":"field_5af34c8db61a2","operator":"==","value":"image"}]],"wrapper":{"width":"","class":"","id":""},"return_format":"array","preview_size":"thumbnail","library":"all","min_width":"","min_height":"","min_size":"","max_width":"","max_height":"","max_size":"","mime_types":"","parent_repeater":"field_5af34b7d054c0"}],"rows_per_page":20},{"key":"field_5b2aaeea085a7","label":"<i class=\"dashicons dashicons-admin-generic\"/>","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5af34991054bd","label":"Affichage","name":"layout","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"container":"Conteneur","fluid":"Fluide"},"allow_null":0,"default_value":"container","layout":"horizontal","return_format":"value"},{"key":"field_5b2ab07c085a9","label":"Marges","name":"content_spacing","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"margin":"Marges","nomargin":"Aucune"},"allow_null":0,"default_value":"margin","layout":"horizontal","return_format":"value"},{"key":"field_5af349c2054be","label":"Alignement du contenu","name":"position","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"textleft":"<i class=\"dashicons dashicons-editor-alignleft\"/>","textcenter":"<i class=\"dashicons dashicons-editor-aligncenter\"/>","textright":"<i class=\"dashicons dashicons-editor-alignright\"/>"},"allow_null":0,"default_value":"textleft","layout":"horizontal","return_format":"value"},{"key":"field_5af34b6b054bf","label":"ID","name":"block_id","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5b2ab04b085a8","label":"Classe","name":"block_class","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""}],"min":"","max":""},"5af34e998f1c9":{"key":"5af34e998f1c9","name":"photo_gallery","label":"Galerie photo","display":"block","sub_fields":[{"key":"field_5b2ab670518ad","label":"Contenu","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5af34f0d8f1cc","label":"Galerie","name":"gallery","aria-label":"","type":"gallery","instructions":"","required":1,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"min":5,"max":"","insert":"append","library":"all","min_width":"","min_height":"","min_size":"","max_width":"","max_height":"","max_size":"","mime_types":"","return_format":"array","preview_size":"medium"},{"key":"field_5b2ab681518ae","label":"<i class=\"dashicons dashicons-admin-generic\"/>","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5af34ea78f1ca","label":"Affichage","name":"layout","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"container":"Conteneur","fluid":"Fluide"},"allow_null":0,"default_value":"container","layout":"horizontal","return_format":"value"},{"key":"field_5b2ab765260ce","label":"Marges","name":"content_spacing","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"margin":"Marges","nomargin":"Aucune"},"allow_null":0,"default_value":"margin","layout":"horizontal","return_format":"value"},{"key":"field_5af34ee38f1cb","label":"Goutières","name":"gutters","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"choices":{"gutters":"Goutières","nogutters":"Aucune"},"allow_null":0,"default_value":"nogutters","layout":"horizontal","return_format":"value"},{"key":"field_5b2ab7e1c4533","label":"ID","name":"block_id","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5b2ab7e7c4534","label":"Classe","name":"block_class","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""}],"min":"","max":""},"5b2a974e54c75":{"key":"5b2a974e54c75","name":"woocommerce_carousel","label":"Carrousel Woocommerce","display":"block","sub_fields":[{"key":"field_5b2ab8718065e","label":"Contenu","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5b2a979754c77","label":"ID","name":"block_id","aria-label":"","type":"text","instructions":"","required":1,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5b2a98ef54c7b","label":"Items par carrousel","name":"post_per_page","aria-label":"","type":"number","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"25","class":"","id":""},"default_value":12,"placeholder":"","prepend":"","append":"","min":8,"max":"","step":""},{"key":"field_5b2a97d754c78","label":"Titre","name":"title","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5b475915de4ad","label":"Préfixe","name":"font_awesome_prefix","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"fas","placeholder":"","prepend":"","append":"","maxlength":4},{"key":"field_5b475930de4ae","label":"Icône fontawesome","name":"font_awesome","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5b3ce908eec5b","label":"Type de carrousel","name":"type","aria-label":"","type":"select","instructions":"","required":1,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"choices":{"category":"Catégorie","new":"Nouveauté","lowstock":"Quantitée Faible","nostock":"Quantitée Épuisée","event":"Évènement"},"default_value":["category"],"allow_null":0,"multiple":0,"ui":0,"return_format":"value","ajax":0,"placeholder":"","create_options":0,"save_options":0},{"key":"field_5b3ceb86a9053","label":"Type de lien","name":"link_type","aria-label":"","type":"select","instructions":"","required":1,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"choices":{"category":"Catégorie","link":"Lien","event":"Évènement"},"default_value":["category"],"allow_null":0,"multiple":0,"ui":0,"return_format":"value","ajax":0,"placeholder":"","create_options":0,"save_options":0},{"key":"field_5b3cebd3a9054","label":"Lien","name":"link","aria-label":"","type":"link","instructions":"","required":0,"conditional_logic":[[{"field":"field_5b3ceb86a9053","operator":"==","value":"link"}]],"wrapper":{"width":"","class":"","id":""},"return_format":"array"},{"key":"field_5b2a97f254c79","label":"Catégorie des produits","name":"product_categories","aria-label":"","type":"taxonomy","instructions":"","required":0,"conditional_logic":[[{"field":"field_5b3ce908eec5b","operator":"==","value":"category"}]],"wrapper":{"width":"","class":"","id":""},"taxonomy":"product_cat","field_type":"checkbox","allow_null":0,"add_term":0,"save_terms":0,"load_terms":0,"return_format":"object","multiple":0,"bidirectional_target":[]},{"key":"field_5b2a985c54c7a","label":"Lien vers la catégorie","name":"product_category","aria-label":"","type":"taxonomy","instructions":"","required":0,"conditional_logic":[[{"field":"field_5b3ceb86a9053","operator":"==","value":"category"}]],"wrapper":{"width":"","class":"","id":""},"taxonomy":"product_cat","field_type":"select","allow_null":0,"add_term":1,"save_terms":0,"load_terms":0,"return_format":"id","multiple":0,"bidirectional_target":[]},{"key":"field_5bc4b844693d6","label":"Évènements","name":"product_events","aria-label":"","type":"taxonomy","instructions":"","required":0,"conditional_logic":[[{"field":"field_5b3ce908eec5b","operator":"==","value":"event"}]],"wrapper":{"width":"","class":"","id":""},"taxonomy":"evenements","field_type":"checkbox","add_term":0,"save_terms":0,"load_terms":0,"return_format":"object","multiple":0,"allow_null":0,"bidirectional_target":[]},{"key":"field_5bc4b871693d7","label":"Lien vers l'évènement","name":"product_event","aria-label":"","type":"taxonomy","instructions":"","required":0,"conditional_logic":[[{"field":"field_5b3ce908eec5b","operator":"==","value":"event"}]],"wrapper":{"width":"","class":"","id":""},"taxonomy":"evenements","field_type":"select","allow_null":0,"add_term":0,"save_terms":0,"load_terms":0,"return_format":"id","multiple":0,"bidirectional_target":[]},{"key":"field_5b2ab8818065f","label":"<i class=\"dashicons dashicons-admin-generic\"/>","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5b2a976054c76","label":"Affichage","name":"layout","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"50","class":"","id":""},"choices":{"container":"Conteneur","fluid":"Fluide"},"allow_null":0,"default_value":"container","layout":"horizontal","return_format":"value"},{"key":"field_5b2ab8f880661","label":"Marges","name":"content_spacing","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"50","class":"","id":""},"choices":{"margin":"Marges","nomargin":"Aucune"},"allow_null":0,"default_value":"margin","layout":"horizontal","return_format":"value"},{"key":"field_5bc49460567a8","label":"Theme du carrousel","name":"event_type","aria-label":"","type":"select","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"50","class":"","id":""},"choices":{"halloween":"Halloween","christmas":"Noël","valentine":"St-Valentin","easter":"Pâques","black-friday":"Black Friday"},"default_value":[],"allow_null":1,"multiple":0,"ui":0,"return_format":"value","ajax":0,"placeholder":"","create_options":0,"save_options":0},{"key":"field_5b2ab8bd80660","label":"Classe","name":"block_class","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"50","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5c015173f65ab","label":"Cookie","name":"has_cookie","aria-label":"","type":"true_false","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"message":"","default_value":1,"ui":0,"ui_on_text":"","ui_off_text":""}],"min":"","max":""},"layout_5b4f8f3c0967e":{"key":"layout_5b4f8f3c0967e","name":"twocols_cta","label":"Bandeau deux colonnes","display":"block","sub_fields":[{"key":"field_5b4f8f5d0967f","label":"Section gauche","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5b4f8f7109680","label":"Titre","name":"title_left","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5b4f8f7b09681","label":"Texte","name":"content_left","aria-label":"","type":"wysiwyg","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","tabs":"all","toolbar":"full","media_upload":1,"delay":0},{"key":"field_5b4f8f8909682","label":"Lien","name":"link_left","aria-label":"","type":"link","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"return_format":"array"},{"key":"field_5b4f8f9809683","label":"Image","name":"image_left","aria-label":"","type":"image","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"return_format":"array","preview_size":"thumbnail","library":"all","min_width":"","min_height":"","min_size":"","max_width":"","max_height":"","max_size":"","mime_types":""},{"key":"field_5b4f8fd009684","label":"Section droite","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5b4f8fdd09685","label":"Titre","name":"title_right","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5b4f8fe509686","label":"Texte","name":"content_right","aria-label":"","type":"wysiwyg","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","tabs":"all","toolbar":"full","media_upload":1,"delay":0},{"key":"field_5b4f8fef09687","label":"Lien","name":"link_right","aria-label":"","type":"link","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"return_format":"array"},{"key":"field_5b4f900109688","label":"Image","name":"image_right","aria-label":"","type":"image","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"return_format":"array","preview_size":"thumbnail","library":"all","min_width":"","min_height":"","min_size":"","max_width":"","max_height":"","max_size":"","mime_types":""}],"min":"","max":""},"layout_5ba3f7003a391":{"key":"layout_5ba3f7003a391","name":"woocommerce_categories","label":"Catégories Woocommerce","display":"block","sub_fields":[{"key":"field_5ba3f7813a394","label":"Contenu","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5ba3f7283a392","label":"Titre","name":"title","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5ba3f7323a393","label":"Catégories","name":"woocommerce_categories_repeater","aria-label":"","type":"repeater","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"collapsed":"","min":0,"max":0,"layout":"block","button_label":"Ajouter un élément","sub_fields":[{"key":"field_5ba3fa2ad0a0f","label":"Catégorie","name":"category","aria-label":"","type":"taxonomy","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"taxonomy":"product_cat","field_type":"select","allow_null":0,"add_term":0,"save_terms":0,"load_terms":0,"return_format":"object","multiple":0,"bidirectional_target":[],"parent_repeater":"field_5ba3f7323a393"},{"key":"field_5ba3fa8dd0a10","label":"Préfixe Font Awesome","name":"font_awesome_prefix","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":"","parent_repeater":"field_5ba3f7323a393"},{"key":"field_5ba3faa5d0a11","label":"Classe Font Awesome","name":"font_awesome","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":"","parent_repeater":"field_5ba3f7323a393"}],"rows_per_page":20},{"key":"field_5ba3f78d3a395","label":"<i class=\"dashicons dashicons-admin-generic\"/>","name":"","aria-label":"","type":"tab","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"placement":"top","endpoint":0,"selected":0},{"key":"field_5ba3f86f3a396","label":"Affichage","name":"layout","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"choices":{"container":"Conteneur","fluid":"Fluide"},"allow_null":0,"default_value":"","layout":"horizontal","return_format":"value"},{"key":"field_5ba3f8a03a397","label":"Marges","name":"content_spacing","aria-label":"","type":"button_group","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"choices":{"margin":"Marges","nomargin":"Aucune"},"allow_null":0,"default_value":"","layout":"horizontal","return_format":"value"},{"key":"field_5ba3f8cf3a398","label":"ID","name":"block_id","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""},{"key":"field_5ba3f8d63a399","label":"Classe","name":"block_class","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","placeholder":"","prepend":"","append":"","maxlength":""}],"min":"","max":""},"layout_649c326fc31d0":{"key":"layout_649c326fc31d0","name":"faq","label":"FAQ","display":"block","sub_fields":[{"key":"field_649c327dc31d2","label":"Repeater","name":"faq_repeater","aria-label":"","type":"repeater","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"layout":"table","min":0,"max":0,"collapsed":"","button_label":"Ajouter un élément","rows_per_page":20,"sub_fields":[{"key":"field_649c32abc31d3","label":"Question","name":"faq_repeater_question","aria-label":"","type":"text","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","maxlength":"","placeholder":"","prepend":"","append":"","parent_repeater":"field_649c327dc31d2"},{"key":"field_649c32c3c31d4","label":"Réponse","name":"faq_repeater_reponse","aria-label":"","type":"wysiwyg","instructions":"","required":0,"conditional_logic":0,"wrapper":{"width":"","class":"","id":""},"default_value":"","tabs":"all","toolbar":"full","media_upload":1,"delay":0,"parent_repeater":"field_649c327dc31d2"}]}],"min":"","max":""}},"min":"","max":"","button_label":"Ajouter un bloc"}],"location":[[{"param":"post_type","operator":"==","value":"page"}],[{"param":"post_type","operator":"==","value":"post"}],[{"param":"post_type","operator":"!=","value":"slide"}]],"menu_order":0,"position":"normal","style":"default","label_placement":"top","instruction_placement":"label","hide_on_screen":"","active":true,"description":"","show_in_rest":0,"display_title":""}]
March 26, 2026 at 1:23 pm #17929188
Vincent Dagenais
Oh great news,
I was able to remove the error.
For a reason I do not understand, I just remove a specific condition on the display of a group field and the error just disappear.
I remove the last one.
And the error just disappear.
Great news!
