Last updated by Andreas Neuber 6 years, 5 months ago.
Assigned support staff: Andreas Neuber.
March 27, 2013 at 9:39 am #115244
ooluja
Is there a way to translate the default URL slug for woocommerce?
My website's default language is Italian and the second language is Croatian. I can easily change croatian slugs for product, product-category and product-tag but my default slugs are not in italian but in english.
It needs to be:
Italian (default) - prodotto
Croatian - proizvod
I have attached a picture.
Thx!
March 27, 2013 at 10:53 am #115266
Andreas Neuber
Hi Ooluja,
I'm assuming that you are using these versions...
> WP 3.5.1
> WooCommerce 2.0.5
> WooCommerce-Multilingual 2.0
> WPML 2.7.1
> WPML String-Translation 1.6.1
..if not its good to upgrade.
Then please go to..
and take a screen-shot of your settings there and post it here.
Based on this we should be able to give you more information.
March 27, 2013 at 12:38 pm #115305
ooluja
I'm using:
> WP 3.4.1
> WooCommerce 1.6.3
> WPML 2.7.1
I didn't upgrade WP and WooCommerce.
Picture attached.
Thx andreas 🙂
March 27, 2013 at 1:26 pm #115321
Andreas Neuber
Hi Ooluja,
Thanks a lot.
Could you update to the newest Woocommerce version?
Because there is whole new section for shop slugs on the permalink settings page which should help you.
March 27, 2013 at 1:34 pm #115327
ooluja
Ok, I will try with the update, I will not remove the version that I'm using now, in case if something goes wrong 🙂
Will post later here if that resolved the problem.
Thx 🙂
March 28, 2013 at 7:43 am #115463
Andreas Neuber
Good - please keep me updated.
The topic ‘[Closed] WPML and Woocommerce – URL slug problem’ is closed to new replies.
