Last updated by Bigul 1 year, 2 months ago.
July 18, 2019 at 11:14 am #4237943
mikaelG-6
I am trying to: Display a product bundle with variable products limited to only on variation on each product and the output for secondary language isn't working as the translated products doesn't respect the setting "Override Default Selections" under the Bundled Products settings.
In the default language I have set the bundle to contain a specific variation of a variable product. But on the secondary language this setting reverts back to "No default value" (translated from Swedish, so I really don't know the real english phrase for this setting). Which causes the product bundle to display a drop-down menu for each variable product in the bundle on the secondary language product details page.
Link to a page where the issue can be seen: Here you can see the default language output for the bundled product: hidden link
And here you can see the secondary language output: hidden link
And it doesn't matter if I manually change the Bundle Product setting "Override Default Selections" using the WooCommerce product editor. After saving the setting reverts from the variation I set to the default "No default value".
So I would really appreciate if you can fix this issue asap.
July 18, 2019 at 4:01 pm #4240671
Bigul
Welcome to the WPML support forum. I will do my best to help you to resolve these issues.
I would like to access the admin area of your site for further checking. Please fill the private details fields after a full site backup.
Please check the following links for more details about our private information sharing policies.
Bigul
July 18, 2019 at 5:42 pm #4241545
mikaelG-6
Hi.
I am sorry, but I don't want to give away access to my site. I gave you clear description of the problem. And either WPML or your plugin WooCommerce Multilingual isn't respecting the settings at the checkbox "Override Default Selections" for the translated product (product bundle) and any changes to this setting directly in the WooCommerce default editor reverts back to "No value" after saving the translated product.
July 18, 2019 at 6:13 pm #4241707
Bigul
Thank you for the updates. I will check about this with our team. So one request. Please share a couple of screenshots of Product settings(the one having the issue) for a better understanding of the issue.
Bigul
July 21, 2019 at 1:09 am #4250633
mikaelG-6
Hi.
I will get back with screen shots in a couple of days, as I am currently on vacation.
I can also add in the meantime, that the plugin developer of Product Bundles (SomewhereWarm) said that the issue is with WooCommerce Multilingual and that you are welcome to reach out to them for further assistance to make sure your plugin is fully compatible with theirs as you advertise here: https://wpml.org/plugin/woocommerce-product-bundles-2/
Mikael
July 22, 2019 at 2:02 pm #4258261
Bigul
Hi Mikael,
Thank you for the updates. As a part of our compatibility escalation procedures, I have tried to reproduce the issue in the test installation. But not able to reproduce it exactly(maybe not much familiar with Product Bundles). So I have created a test site in our Sandbox server. Please check the following URL.
It is a fresh installation. Please configure WPML & WooCommerce like your live site and check the bug is replicable or not. It will help us a lot. We can forward it directly to our developers for further debugging.
Bigul
July 22, 2019 at 2:49 pm #4258883
mikaelG-6
Done.
I did it reversed from my own site to save time. So default language is English. Secondary language is Swedish.
So check this product in default language: hidden link
And check it in secondary language: hidden link
As you can see on the default language, there is no drop-down menu below "Size *". If you check secondary language, there is a drop-down for the same product.
You can use the language switcher in the footer to switch between the languages.
Checkout the screenshots from the product setting for the bundled product on the default language and on the secondary language. I have highlighted the setting that isn't being enforced on the secondary language.
Even if you change the setting to the attribute you want to be displayed as only choice on secondary language, it reverts back to "No default Size" after saving.
July 23, 2019 at 2:22 pm #4266991
Bigul
Hi Mikael,
Thank you for reproducing the issue. The bug is existing after the initial debugging steps. Therefore I am escalating the ticket to our compatibility team for further debugging. We will get back to you as early as possible. Please wait.
Bigul
July 26, 2019 at 8:57 am #4288473
mikaelG-6
Any news on this? Really need this to be fixed.
July 26, 2019 at 1:08 pm #4289769
Bigul
Hi Mikael,
For your kind updates, our compatibility team is currently working on this issue. We will get back to you soon when we have an update from our team. Please wait.
Bigul
August 2, 2019 at 9:20 am #4328433
Bigul
Hi Mikael,
For your kind information, the issue is escalated to our Compatibility Dev team for fixing. We will fix this issue with the help of WooCommerce Product Bundles team.
We will get back to you soon when we have an update from our team on this. Please wait.
Bigul
September 1, 2019 at 4:05 am #4492005
mikaelG-6
Almost a month and no fix?! This is really bad support from your Dev team. I have payed much money for WPML and WooCommerce Product Bundles and issues like this should be handled promptly, especially when you claim that they are compatible.
September 2, 2019 at 7:17 am #4494935
Bigul
Hi Mikael,
Sorry for the inconveniences. For your kind updates, the issue is happening because of the compatibility conflicts with WooCommerce Multilingual plugin and WooCommerce Product Bundles team. Our developers are currently working on the fix now.
We will get back to you as soon as possible when we have feedback from our team on this. Please wait.
Bigul
November 24, 2019 at 5:18 am #5005861
Bigul
Hi Mikael,
Sorry for the late response. This issue is fixed in the development version of WPML and WooCommerce Multilingual. The fix will be included in the upcoming version of the plugins.
We will get back to you as soon as possible when we have update from our developers about the release. Please wait.
Bigul
December 28, 2019 at 11:29 am #5204379
Bigul
Hi Mikael,
Sorry for the inconvenience. We have released a new version of WPML and WooCommerce Multilingual recently. It has included the fix for the bug. Please upgrade to the latest versions of WooCommerce, WPML and WooCommerce Multilignaul after a full site backup. Then update the product and its translations(just resave) and check the bug is existing or not.
Bigul
