WordPress 6.7 has introduced a new issue that impact translations, please update WooCommerce and WPML to the latest versions before you report issues. More about this here - https://wpml.org/errata/php-error-wp-6-7-notice-function-_load_textdomain_just_in_time-was-called/
9:00 – 15:00 9:00 – 15:00 9:00 – 15:00 9:00 – 15:00 9:00 – 15:00 - -
Last updated by Christopher Amirian 1 day, 14 hours ago.
November 27, 2024 at 2:15 pm #16450425
mateuszR-5
I am trying to configure WPML on my site hidden link. I want the main language to be 'beztrafice.fuchs.com', the English language to be 'welubricate.fuchs.com', and other languages like 'welubricate.fuchs.com/es' and 'welubricate.fuchs.com/de'.
I am unsure if this configuration is possible with the WPML plugin.
Is it possible to configure WPML to have different domains for different languages as described?
Can WPML support a multisite setup or any other solution to achieve this configuration?
November 27, 2024 at 2:38 pm #16450606
Christopher Amirian
As I did not get an answer in the Chat, I moved it to this ticket.
It is not possible to do that with WPML.
You either can select a separate domain mode or the directory mode.
You can not mix and match them and it is not possible to achieve the thing you want via multi-site setup.
So you either need to have this mode:
domain.com
domain.com/en
domain.com/es
Or you have this mode:
domain.com
en.domain.com
es.domain.com
For more information regarding the separate domain mode:
https://wpml.org/documentation/getting-started-guide/language-setup/language-url-options/how-to-use-wpml-with-different-domains-per-language/
