This topic contains 24 replies, has 2 voices.
Last updated by Noman 1 year, 2 months ago.
Assigned support staff: Noman.
December 17, 2018 at 7:58 am #3006964
lihongl
Tell us what you are trying to do?lynn:When I want to add pages in other languages in the wp background, the page is invalid.
Is there any documentation that you are following?lynn:You can go to my wp website account to see.
The page error prompt is a screenshot in the attachment
December 17, 2018 at 12:58 pm #3008256
Noman
Thank you for contacting WPML Support. Could you please add this to the top of wp-config.php to increase WP memory:
/* WP Memory Limit */
If still issue persists, please add the debug report in the Debug Information box. I have also enabled debug info box for your next reply: https://wpml.org/faq/provide-debug-information-faster-support/
Thank you
December 18, 2018 at 7:22 am #3011148
lihongl
Please check my information, please help me find the error
December 18, 2018 at 9:27 am #3011422
lihongl
Can you mark my next reply as private, please? I will give you WP-admin and FTB accounts.I urgently need to solve the problem, please
December 18, 2018 at 10:13 am #3011575
Noman
Yes I have enabled private reply box, please provide WP and FTP login info so I can debug further.
December 18, 2018 at 6:10 pm #3013381
Noman
Thanks for logins it is enough for now to debug this. I dont need more files at moment. I will get back to you with my findings.
December 19, 2018 at 1:53 pm #3016614
Noman
I have tried to login to your site but I couldn’t succeeded due to various Fatal errors in your site that coming from
Your theme and some plugin as follows:
Revolution slider:
Fatal error: Out of memory (allocated 8388608) (tried to allocate 32768 bytes) in /var/www/html/Macaon8s/wp-content/plugins/revslider/includes/output.class.php on line 3645
Visual Composer:
Fatal error: Out of memory (allocated 8388608) (tried to allocate 65536 bytes) in /var/www/html/Macaon8s/wp-content/plugins/js_composer/include/helpers/helpers_api.php on line 30
Woocommerce:
Fatal error: Out of memory (allocated 6553600) (tried to allocate 32768 bytes) in /var/www/html/Macaon8s/wp-content/plugins/woocommerce/includes/libraries/action-scheduler/classes/ActionScheduler.php on line 1
Fatal error: Out of memory (allocated 6553600) (tried to allocate 32768 bytes) in /var/www/html/Macaon8s/wp-content/plugins/woocommerce/includes/log-handlers/class-wc-log-handler-file.php on line 1
DPR Calibra Theme
Fatal error: Out of memory (allocated 6553600) (tried to allocate 32768 bytes) in /var/www/html/Macaon8s/wp-content/themes/dpr-calibra/framework/dpr_functions.php on line 1754
I have deactivated WPML plugin by renaming it from FTP but your site still throwing various errors. It means this problem is not related to WPML plugin.
I recommend you to please ask your hosting provider to clear Server cache or CDN cache so that your site can run normally. OR tell them that memory setting is not reflecting on your site, even though all things are setup correctly.
Thank you
December 19, 2018 at 3:03 pm #3017158
lihongl
Hard work, thank you very much!
Is my theme compatible with this plugin? Then I can't use the WPML plugin now?
December 19, 2018 at 3:09 pm #3017191
Noman
According to theme author they have made it compatible but its not in our official compatibility list: hidden link
However, the issue is not due to theme or plugin but from server side, so you need to contact server hosting support to fix the memory issue, after that your site will work fine. Thanks
December 19, 2018 at 3:13 pm #3017214
lihongl
My service provider said the server is normal. My website is now a new website, so you can try and reinstall WPML for testing. As long as the plugin is installed, the website will not work properly.
December 19, 2018 at 3:14 pm #3017217
Noman
I disabled WPML plugin still same Memory related errors are showing up. So its not related to WPML.
December 19, 2018 at 3:23 pm #3017273
lihongl
I have restarted the server and the website is working fine. You can try installing the WPML plugin and enabling work. Maybe help.Maybe you can restart the server operation? As soon as you start the plugin, it will not work.
December 19, 2018 at 3:28 pm #3017294
Noman
What is the error now, are you getting the same memory error still or what's the issue now?
December 19, 2018 at 3:39 pm #3017355
lihongl
Just stop your plugin, restart the server (the role is to empty the cache), everything is fine.
The plugin is not in a normal state when it is enabled.
December 20, 2018 at 7:14 am #3019205
Noman
I have enabled WPML plugins in your site and they are working perfectly fine and now your site not throwing any error as you can see in attached screenshot. Could you please check and confirm?
Thank you
The topic ‘[Closed] WPML plugin usage problem’ is closed to new replies.
