Last updated by Osama Mersal 2 months, 1 week ago.
Assigned support staff: Osama Mersal.
April 2, 2021 at 1:26 am #8451969
steliosP-4
Hi.
This is my website hidden link
and this is the staging site hidden link
We have problem with the speed causign from the plugin.
As discuss, below is what you can forward to WPML. Even without WPML, the site would need improvement in terms of speed, both in the theme and addressing other plugins, but WPML and it's extra plugins are collectively causing the single biggest speed hit on the server side.
The String Translations plugin is causing the biggest speed hit, with several database queries each adding around 0.1 seconds to load time. Disabling this plugin cuts page generation in half, literally, for some pages. Please can you have a look.
Disabling the rest of the WPML plugins reduces page load time by around another 50%.
April 5, 2021 at 8:33 am #8465179
Osama Mersal
Thanks for contacting WPML forums support. I’ll be glad to help you today.
1) We are sorry for the late reply. Could you please go to WPML-> String Translation and check that "Track where strings appear on the site" and "Auto register strings for translation" features are disabled? (Kindly check the attached screenshot)
2) WPML is a complex plugin that needs some resources, but I think you have many plugins, making it worse because WPML is working under the hood to make all of them translatable. (Kindly check this https://wpml.org/home/minimum-requirements/)
To debug the performance issue you have, kindly check the following guides.
1- https://wpml.org/tutorials/2019/10/analyze-performance-issues-with-query-monitor/
2- https://wpml.org/faq/how-to-debug-performance-problems/
Kindly after installing Query Monitor on your staging site and check, let me know what you found.
Thanks for your cooperation and patience
Osama
The topic ‘[Closed] WPML speed hit’ is closed to new replies.
