Problem: we tried to save some seetings in the "YITH WooCommerce Request a Quote" -Plugin but without any success. The presets appear again. If we just deactivate the WPML String Plugin it works perfect. How can we solve this issue?
Solution: Please follow this steps: - Go to WPML -> String Translation -> Filter by this domains: -- admin_texts_ywraq_privacy_description -- admin_texts_ywraq_privacy_description - Translate this strings to English and save the translations (Don't forget to check the 'Translation is complete' checkbox)
Relevant Documentation:
Last updated by dominikH-11 9 months ago.
August 26, 2019 at 9:26 am #4457169
dominikH-11
Dear WPML Team,
Kind regards
August 26, 2019 at 10:13 am #4457509
Carlos Rojas
1.- Please describe the steps to reproduce the issue. You can attach some screenshots to highlight the problem so I can have a better understanding.
2.- I would like to request temporary access (wp-admin and FTP) to your site to take better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Our Debugging Procedures
Kind regards,
Carlos
August 26, 2019 at 10:23 am #4457557
dominikH-11
Hello Carlos,
thank you for your replay.
Unfortunately we are not allowed to share access.
I added a scrrenshot. If just want to change anything like a letter in a the field and try to save it the page loads new but changes are not saved.
If we deactivate WPML String Translation Plugin, changes are working perfect.
Kind regards
August 26, 2019 at 10:38 am #4457719
Carlos Rojas
Is is possible for you to create a test site with a copy of the production site and share access to that test site?
Carlos
August 26, 2019 at 11:33 am #4458035
dominikH-11
Hi Carlos,
would it just be possible to reset all the String Translation Settings.
Kind reagrds
August 26, 2019 at 11:40 am #4458061
Carlos Rojas
I can't tell if this is a solution as I haven't been able to see the issue and reproduce it. That's why in my previous message I asked if you could create a test site and share access.
When we isolate the cause of the issue then we can find a solution.
Carlos
August 26, 2019 at 1:57 pm #4459433
dominikH-11
I will send you the login data.
Where i can send you?
Kind regards
August 26, 2019 at 2:00 pm #4459447
Carlos Rojas
Thank you for your feedback.
I have set your next answer private. There you will find the necessary fields to provide the access data in a secure way.
Carlos
August 26, 2019 at 3:01 pm #4459993
Carlos Rojas
Could you tell me if the issue persists?
Carlos
August 27, 2019 at 6:43 am #4463097
dominikH-11
My issue is resolved now. Thank you! 🙂
August 27, 2019 at 8:44 am #4463885
Carlos Rojas
I'm glad to hear that the issue is solved 🙂
Please don't hesitate to contact us if you need our help in the future with WPML. We will be more than happy to help.
Carlos
August 27, 2019 at 10:01 am #4464679
dominikH-11
Hi Carlos,
thank you very much for helping us.
We translated everything. The problem is now that on the english version is still the german button label and link.
August 27, 2019 at 11:08 am #4465701
Carlos Rojas
As this ticket is already closed I kindly ask you to open a new one describing the steps to follow in order to reproduce the issue and share access credentials again (once the ticket is closed the credentials are automatically deleted for security reasons).
Thank you very much for your understanding!
Carlos
August 27, 2019 at 1:33 pm #4467319
dominikH-11
