Last updated by Lauren 1 year, 1 month ago.
April 22, 2019 at 6:29 pm #3657861
kamilB-4
Every time I activate the plugin some parts of the site are shut down or not working. It is no longer possible to update other plugins as it cannot create directories etc. But every time I turn it off, everything works again.
Also our extra pictures of our products are not shown.
How can we solve this?
April 22, 2019 at 8:11 pm #3658099
Bobby
to understand the issue best please provide me with some additional information regarding the parts of the site that shut down
are there any warnings or errors that display ? if just a blank page are there any warnings/errors within the console log ? (right click->inspect->console log)
additionally please provide me with some more information on the issue of updating/installing plugins when WPML is activated
(screenshots can be helpful to better understand the issue as well)
Also if possible I would need to see the detail of the error log. You can see how to enable debug logging here:
Go in your wp-config.php file and look for define(‘WP_DEBUG’, false);. Change it to:
define('WP_DEBUG', true);
Edit your wp-config.php file and add these lines, just before it says 'stop editing here':
ini_set('log_errors',TRUE);
ini_set('error_reporting', E_ALL);
ini_set('error_log', dirname(__FILE__) . '/error_log.txt');
This will create an error_log.txt file in your site's root directory. Please send me its contents.
Thank you !
April 25, 2019 at 11:55 am #3681983
kamilB-4
It get fixed 1 day after the upgrade but then, all is not good again. It feels like the page is loading some time and then it´s brokes.
Also when I wanna to upgrade others plugins. When I have string activeted then its not going. When I disable String then I can update all the plugins.
Is like the plugin is hitting all over my site.
April 25, 2019 at 7:04 pm #3685281
Lauren
Hi there, Bobby is off today, but as mentioned in his earlier reply, please enable the debug log and post any errors that are recent. That might be able to point in the right direction of where the problem is coming from.
Also, To ensure the quickest and most accurate support, please provide your debug information so that I can get a look at some of your configurations. We have an excellent article on how to located here: https://wpml.org/faq/provide-debug-information-faster-support/.
NOTE: Please be sure to check the box to indicate you can provide debug info and paste your debug info in the debug field provided, and NOT in the general response field.
The topic ‘[Closed] WPML String Translation – problem’ is closed to new replies.
