Last updated by Yvette 10 months ago.
August 1, 2019 at 1:24 pm
petrS-7
I am trying to: solve the problem with "It looks like languages per directories will not function"
I expected to see: no red warning messages, but I tried to solve this according this post https://wpml.org/documentation/getting-started-guide/language-setup/cannot-activate-language-directories/ but in .htaccess is everything correct.
Instead, I got:
August 1, 2019 at 6:18 pm #4324627
Yvette
hello
The problem might be related to this error message: "cURL error 28: connect() timed out!"
Can you please ask your server/hosting support for assistance to install the latest CURL extension on your site.
Here is more info on this:
Please try this and let me know if it resolves the issue.
August 5, 2019 at 1:03 pm #4340705
petrS-7
which curl version is mandatory to have? We have older linux server and we have curl 7.19.7 and cant upgrade it without the upgrade of server.
August 5, 2019 at 3:07 pm #4341549
Yvette
I am not sure, to be honest, but this problem can happen with older versions of curl. I¨ll try installing your duplicator package on a local server to eliminate the possibility that this is indeed the issue.
I´ll get back to you as soon as I can.
August 5, 2019 at 4:38 pm #4342033
Yvette
It seems like the version required is at least: I think 7.34.0
See https://wpml.org/errata/wpml-could-not-load-configuration-files-which-your-site-needs/
Perhaps to rule out the possibility that this is the heart of the problem, you can send me a copy of your site for me to install on my local server. If my local server has the same issue - then we know it is not related to the cURL library since my PHP has the required level.
More here:
https://wpml.org/faq/provide-supporters-copy-site/
I´m opening the private area for a download link to the Duplicator pcackage. Please use a file sharing service like WeTransfer and do not attempt to upload the files to the forum.
THanks
The topic ‘[Closed] WPML tells me "It looks like languages per directories will not function"’ is closed to new replies.
