Last updated by Mateus Getulio 2 months, 3 weeks ago.
Assigned support staff: Mateus Getulio.
July 4, 2022 at 7:04 pm #11600329
ceciliaC-7
I am trying to: Activate the plugin
I expected to see: This plugin has been deactivated as it is now part of the WPML Multilingual CMS plugin. You can safely delete it.
Instead, I got:
July 5, 2022 at 4:31 pm #11607871
Mateus Getulio
Hey there,
Thanks for your contact, and welcome to the WPML support forum!
Since WPML 4.5, the Translation Management module was incorpored in the main plugin (WPML Multilingual CMS), so you don't need to have it anymore in your plugins list. Therefore, you can safely delete it and keep using WPML as you used to do.
If you're experiencing issues with this, please let us know better what's happening and we'll check it. Looking forward to your reply, thanks!
Kind regards,
Mateus.
