Last updated by daanV-5 1 year, 7 months ago.
October 10, 2018 at 11:36 am #2804011
daanV-5
I have some multi-site with some shop. This shop would be multilingual on some different domains. Normally I would set some check under the options 'Language URL-format'. Now is the options on some different domains not possible with multi-sites.
I found some information about this support item: https://wpml.org/documentation/support/multisite-support/languages-in-domains-for-wordpress-multisite-mode/
The known issue of this support-item is that things will not work when the URLs used for the secondary languages are using the https protocol.
Is there some sollution for this problem. I would use the option to set the different languages on some different domains that uses the https protocol.
October 11, 2018 at 7:51 am #2807034
Shekhar Bhandari
Hello there,
I am sorry to let you know that there are no any solutions available for the limitation, https://wpml.org/documentation/support/multisite-support/languages-in-domains-for-wordpress-multisite-mode/#known-limitations
You can try to use some custom programming work to make this work, which is beyond the scope of our support.
At this point I would suggest you consider contacting one of our certified partners from this link:
http://wpml.org/documentation/support/wpml-contractors/
Before doing so please have a look also here:
http://wpml.org/documentation/support/wpml-contractors/guidelines-for-people-looking-for-consulting-help/
You will get the custom assistance you need to get on with your project.
October 11, 2018 at 12:01 pm #2808027
daanV-5
Thanks for your reply!
In the admin stays that it is still not available. Is there some expectation when this will be available?
Is WPML working on this problem at this moment?
I hope to hear from you.
October 12, 2018 at 8:01 am #2811058
Shekhar Bhandari
Hello there,
I am gathering more information about this issue from our records at the moment.
I will respond to you as soon as possible.
October 15, 2018 at 9:18 am #2816752
Bigul
I am Bigul from WPML support team. Shekhar is on vacation now. So I am taking care of this ticket. Hope it will be okay for you.
For your kind updates, at this moment we don't have more information about the changes or expected the date or timeframe. It is still a feature request. Thank you for the understanding.
Bigul
October 27, 2018 at 7:43 am #2854872
daanV-5
I have a question. Is it possible to change the language in the functions with some function like in this thread: https://wpml.org/forums/topic/how-to-set-the-language-of-existing-posts-programmatically/
I hope it is possible to change the language hard on some URL. Is it possible in this kind of way?
Hope to hear from you.
