Last updated by steveS-12 4 months, 3 weeks ago.
Assigned support staff: Radu.
September 26, 2019 at 6:19 pm #4649623
steveS-12
I'm using the following PHP to output the French translation URL of the corresponding English page:
apply_filters( 'wpml_permalink', $url , 'fr' )
This works on all pages of my site except for the events calendar pages, i.e.
/events
/evente/event-title
On these pages the code outputs nothing.
You can see this occurring here:
September 27, 2019 at 4:52 am #4651713
Radu
Hey Steve,
I checked this out and it seems that this issue about the Events Calendar slug is already on our list. According to my colleagues tests, this is something that needs to be changed on both WPML and Events Calendar plugin.
I already added this ticket to the issue on our list so I can keep you posted about the progress we're making on this. Also, I will try to come back with an early fix if possible (once we manage to fix this).
Radu
September 27, 2019 at 3:32 pm #4655615
steveS-12
Hi Radu, is there a WPMU function that will provide the corresponding translated post ID that may work with the Events Calendar? If I can just generate the post_id I can do the rest with finding the permalink.
October 1, 2019 at 5:32 am #4668781
Radu
Hey Steve,
I think that you can use this hook to get the ID of the translated event: https://wpml.org/wpml-hook/wpml_object_id/. You can find a bit more details about this right here: https://wpml.org/documentation/support/creating-multilingual-wordpress-themes/language-dependent-ids/#2-manually-using-the-wpml_object_id-function
Radu
October 4, 2019 at 3:13 pm #4696837
steveS-12
Thanks. This is what I ended up using that works but not exactly ideal-
if ($post_type != 'tribe_events') {
	$url = get_the_permalink();
	$url_en = apply_filters( 'wpml_permalink', $url , 'en' );
	$url_fr = apply_filters( 'wpml_permalink', $url , 'fr' );
if ($post_type == 'tribe_events') {
	$event_post_id_en = apply_filters( 'wpml_object_id', $post_id, 'tribe_events', FALSE, 'en' );
	$event_post_id_fr = apply_filters( 'wpml_object_id', $post_id, 'tribe_events', FALSE, 'fr' );
	$url_en = '/event/'.get_post($event_post_id_en)->post_name;
	$url_fr = '/fr/event/'.get_post($event_post_id_en)->post_name;
if ($_SERVER['REQUEST_URI'] == '/events/' || $_SERVER['REQUEST_URI'] == '/fr/events/') {
	$url_fr = '/fr/events/';
	$url_en = '/events/';
