Supporter timezone: Europe/Madrid (GMT+02:00)
Last updated by Carlos Rojas 2 months ago.
Assisted by: Carlos Rojas.
July 2, 2026 at 6:48 am
benoitF-4
Hello there, since many months i discover an issue that's not good for my SEO.
The SEO metadata for some products categories are displayed in spanish, even if i'm in the French website (my main langage).
Example : hidden link
I make some deep analyses about this issue and it's like, the issue of wrong metadata langage affect only the categories whose primary langage is spanish. Even if they are correctly translated in french, this issue afect ONLY the SEO metadata... (using yoast premium, yoast woocommerce + WPML Seo)
July 2, 2026 at 3:17 pm #18138060
Lucas Vidal de Andrade
WPML Supporter since 11/2023
Hey there,
I'm still analyzing your issue, I'll check in a local copy, to see if there's any plugins or theme conflict and will keep you updated. Thank you for your patience.
July 3, 2026 at 11:07 am #18139757
Hey there,
I've tried downloading a copy of your website, but the process failed multiple times. To be able to verify the issue and test solutions, I need you to please create a staging (testing) copy of your website on the same server, so I can check for causes and solutions without harming the live website.
You can use a plugin to achieve that, or reach out to your hosting support, and they might be able to help you creating a staging website. Please send me the link to it here, when you are done. Thank you for the cooperation on this matter.
You can keep the same user you've already shared on staging, so I can access it directly.
July 6, 2026 at 4:44 pm #18143871
benoitF-4
Hello there, there is the stagging website with the same issue :
[removed by support]
July 7, 2026 at 9:16 am #18144755
Thank you for sharing. I've escalted your issue to our 2nd tier team, and will let you know as soon as I have relevant information to share. Thank you for your patience.
July 8, 2026 at 7:25 am #18146512
Hello there,
Can you please share access to the production environment (please share an user, with login and PW, instead of the login link).
I may need to replicate your website locally. To do this, I need to temporarily install a plugin called "Duplicator" or "All in One WP Migration" on your website. This will allow me to create a copy of your website and content. Once the issue is resolved, I will delete the local website. Let me know if this works for you.
IMPORTANT
Please make a backup copy of the site files and database before giving us access.
- If you do not see the wp-admin/FTP fields, this means your post and site login details are being made PUBLIC. DO NOT post your website details if you do not see the required wp-admin/FTP fields. If you do not, ask me to enable the private box. The private box looks like this:
July 8, 2026 at 9:21 am #18146682
Thank you for sharing. We still don't know what's causing the issue. On the staging website, I deactivated all unrelated plugins, reactivated them and the issue was gone. Since we only have the issue in production, we'll investigate it there. We won't make any changes to production without checking with you.
July 13, 2026 at 7:53 am #18154263
Carlos Rojas
WPML Supporter since 03/2017
Languages: English (English ) Spanish (EspaƱol )
Our 2nd tier specialists ran several tests, and they decided to escalate this ticket to our development team for further investigation.
I will get back to you as soon as I get feedback from our 2nd tier and developers.
Thank you very much for your patience and understanding!
Carlos
