0
WooCommerce Multilingual is a very important project for us, today we are happy to announce that we have 3 WooCommerce Extensions to add to our compatibility list.
The extensions are Multibanco, Advanced product labels, Catalog mode
Also, if you're a theme or a plugin author and you want to make it compatible with WPML, we welcome you and ready to help: You are welcome to contact us at go global program page.
Multibanco (IfthenPay gateway) for WooCommerce
This plugin allows Portuguese costumers to pay WooCommerce orders with Multibanco (Pag. Serviços), using the IfthenPay payment gateway.
Download Multibanco (IfthenPay gateway) for WooCommerce
Create custom product labels easily and quickly to grab your customer's attention.
Purchase Advanced product labels
YITH WooCommerce Catalog mode
Add a catalog mode for your WooCommerce products
Purchase YITH WooCommerce Catalog mode
