Last updated by dukkanifyt 6 months, 1 week ago.
April 25, 2025 at 2:46 pm #16969115
dukkanifyt
I am trying to load more products on the home page in other languages, such as Arabic or Turkish, using the 'Load more products' button.
The issue can be seen on the home page: hidden link.
However, on the shop page: hidden link,
the product images load normally when using the same button.
When I click the 'Load more products' button at the bottom of the home page, more products are displayed without their images.
This issue does not occur on the shop page, where product images load normally.
Why are product images not loading on the home page when using the 'Load more products' button?
Why does the issue only occur on the home page and not on the shop page?
please help me for make the images loads normally when using the 'Load more products' button
April 26, 2025 at 2:00 am #16970202
Could you please provide more details about which widget is used on the homepage to load the products?
It looks like it is a different widget, than the one used on the Shop page, is this correct?
April 26, 2025 at 10:40 am #16970798
dukkanifyt
Hello, thanks for fast response
Yes, this is correct.
We use Elementor elements
so in home page we use element called "Products (grid or carousel)"
in Shop page we use element called "Archive products"
we can't use same element for home and shop page
also i check now the products image it's work normally ... did you make any updates for this issue
i don't like the problems that solved alone, because it's later will be back alone.
how can we make sure this issue will not be back again?
why i got this issue ?
April 26, 2025 at 2:07 pm #16971013
No, I did not make any changes but it could be that this was a cache issue.
If the issue occurs again, please let me know.
I would say you test this by updating the original page, saving the page, and then applying the translation again. If the issue is currently not replicable, then there is not much we could do from our end. It might have been a temporary issue.
April 26, 2025 at 6:35 pm #16971459
dukkanifyt
Hello, I face the issue again...
on this page :
but home page of the original language:
it's work fine
April 26, 2025 at 7:45 pm #16971564
IMPORTANT
I may need to install a plugin called "All In One WP Migration" to create a copy of the website so I can investigate the issue further.
However, I would also be very grateful if you could provide a staging site or a copy of the website from your server for this purpose.
If you have any questions about creating such a staging site, you can consult your hosting provider. Please note that WPML must also be registered on this staging site at https://wpml.org/account/websites/.
If you are unable to provide such a copy of the website for testing, please let me know on this ticket.
Video:
April 27, 2025 at 2:37 pm #16972429
dukkanifyt
Also i want to add this information
i usually translate with a credits from
WPML > Translation Management
then i select the product for translation
it should to take the image from original language product
April 29, 2025 at 4:19 pm #16980236
The issue is not the product translations, as you can see on the single product pages, the images exist.
The issue is the widget "Products (grid or carousel)" that is used to display the image on the homepage. This is an XThemos Elements Widget - a custom widget of the Woodmart Theme.
Further, it looks like your theme is a customized version of the Woodmart Theme. It this widget is not a default widget that is shipped with Woodmart, you might need to contact the developer who created this widget and request to fix this issue.
Workaround:
Use a different widget to display the products.
I can provide a WPML test site, on which you could install the Woodmart Parent Theme (if this is a default Woodmart Widget) and we will try to recreate the issue. If we can recreate it, I will escalate the issue to our compatilbity team, which then will try to find a solution and contact Walmart so that the issue can get solved.
Would it be possible for you to cooperate on this matter? In case not, then please reach out to Woodmart Support or the person who developed your theme, respectively if this a custom widget that was developed for your theme only.
April 29, 2025 at 9:13 pm #16981085
dukkanifyt
Hello thanks again for your feedback.
in this case i can confirm it's Woodmart Parent Theme and the widget it's default.
we jest add our brand because we are development Company.
YES, we will cooperate this matter.
you can make a copy of our website to your WPML test site. so you will be able to handle this issue.
also from our side we will contact to Woodmart Support.
if any one of us solve this issue will inform each other.
keep in touch...
best regards....
April 29, 2025 at 10:46 pm #16981263
Thank you for your cooperation!
Please do not migrate a copy of your site to this test site. Instead, we only need the latest version of the Woodmart Theme and the Woodmart Core Plugin and we will try to recreate the issue from scratch.
One-Click-Login:
If you could also install and register Elementor PRO it would be highly appreciated. Please leave me a comment once you are done with this task.
May 8, 2025 at 1:03 pm #17011898
dukkanifyt
Hello, I'm really sorry about the delay
we are already add Woodmart Theme
you can do your thing
May 8, 2025 at 6:28 pm #17013415
Until now I can not confirm the issue on this test site:
I will try to take a local copy of your site for further investigation.
May 9, 2025 at 11:59 pm #17018218
On a local copy of your site, the issue does not occur. See screenshot.
I will need to run further tests on your site, to find out what is causing this problem.
Possible reason:
Your site uses various plugins that come with your hosting environment on Hostinger and those plugins cannot operate outside of Hostinger's server environment.
It would be advisable if you could set up a staging site on hosting for running further tests. If you are not aware of how to set up such a staging site, please consult the Hostinger Support Team.
The private reply form is enabled again so that you can provide me access to such a staging site.
This may be unrelated to the issue:
On the copy of your site, I saw this dashboard notice:
"WooCommerce Price Based on Country: It looks like another multicurrency plugin is active on your site. Price Based on Country will not work properly. We recomended you disable WooCommerce Multilingual multiple currencies option."
Note, that running "WooCommerce Price Based on Country" together with our addon "WooCommerce Multilingual & Multi-Currency" might no longer be advisable and lead to unexpected issues. Both plugins share the same API (Maxmind) to calculate prices in WooCommerce which can lead to unexpected outcomes.
May 10, 2025 at 12:33 am #17018267
Note that the issue seems curtrently no longer to occur on your website.
In case you do not need any further assistance, please close this ticket.
May 11, 2025 at 1:56 pm #17020237
dukkanifyt
Thank you.. yes for some reason we never face same issue again
make there is an update already solved the issue.... Thank you for your time
