Waiting for author
Topic Tags: Compatibility
Overview of the issue
When using Slider Revolution and the SR7 rendering engine, you might experience issues such as translated slides appearing empty or not being able to translate slides with WPML.
Workaround
While Slider Revolution is working on a new integration with WPML, you can switch back to the SR6 rendering engine:
  • In the WordPress dashboard, go to Slider Revolution > Globals > Global Settings.
  • Locate the Rendering Engine setting.
  • Select the SR6 engine.
  • Save the changes.
2 risposte a “Slider Revolution - SR7 Engine Not Compatible Yet With WPML”
    • Hi Rafa,
      Our developers have contacted the authors to work together on compatibility.
      At the moment, I can’t provide an ETA, as we are still in the early stages of that collaboration.
Lascia una risposta
Puoi usare questi tag:
