The client is experiencing an issue where the opening text of two Gravity Forms isn't getting translated despite retranslating efforts.
If you're facing a similar issue with your Gravity Forms not translating, we recommend following these steps:
1. Navigate to WPML -> Translation Management -> Translation Jobs and cancel any in-progress job. If there is no in-progress job, proceed to the next step.
2. Edit the form in the original language. Make a minor change (like adding a space at the end of a sentence) and update the page.
3. Go back to WPML -> Translation Management and send this form for translation. Ensure to tick the checkbox, scroll down, and click on translate. You should then see the form in the translations tab.
4. Move to WPML -> Translations, take the form, and translate the page. Save the translation at 100% completion.
This method resolved the issue for another form, and it should work for any similar cases. If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum for further assistance.
Last updated by ayeletG 1 year, 1 month ago.
Assisted by: Lauren.
January 10, 2025 at 6:24 pm #16582889
ayeletG
I have translated all my Gravity Forms, but the opening text of two forms isn't getting translated. I've tried retranslating and nothing seems to work. The issue can be seen on the following pages: hidden link and hidden link.
The opening text of two Gravity Forms isn't getting translated despite retranslating efforts.
Why isn't the opening text of my Gravity Forms getting translated?
What steps can I take to resolve this translation issue?
January 10, 2025 at 7:07 pm #16583125
Lauren
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
January 13, 2025 at 7:28 pm #16590510
ayeletG
Hi Lauren,
I just wanted to check on this and see if it's progressing.
Thanks, Todd
January 13, 2025 at 8:52 pm #16590725
Lauren
Hi there, I was able to resolve this by going to review the translation and accepting the translation, then following these steps:
1. Go to WPML -> Translation Management -> Translation Jobs and cancel the in progress job. If there is no in progress job, continue to the next steps.
2. Edit the form in the original language. Make any small change and update the page. I added a space at the end of a sentence.
3. Go to WPML -> Translation Management and send this form to translation. Tick the checkbox, scroll down and click translate, then you will see the form in the translations tab.
4. Go to WPML -> Translations and take and translate the page. Save the translation 100% and then let's see if the correct content shows.
It worked for me and now I see the translations at hidden link
You can follow these same steps on the other forms, and let me know if that resolves it.
January 14, 2025 at 3:51 pm #16593834
ayeletG
Thanks for your help. That worked for me.
