Pular a navegação
Open
Topic Tags: Compatibility
Overview of the issue
When using Custom Fonts with Elementor and Different domains per language, a Cross-Origin Resource Sharing (CORS) Policy issue arises. The custom fonts are always loaded from the original domain, leading to CORS policy errors.
Workaround
  • Go to WPML > Settings > Post Types Translation
  • Set the post type Custom Fonts (elementor_font) to translate.
  • In the same page but in the Custom Fields Translation section, set the custom field elementor_font_files to translate.
  • Open your translation in ATE.
  • Search for ‘.ttf’ file.
  • Once you find it, translate the domain URL for the right one.
  • Go to Elementor > Tools.
  • Press the to Regenerate Files & Data button.
  • Clear browser cache.
6 Respostas para “Elementor - Custom Fonts Cause CORS Policy Issue With Different Domains Per Language”
  1. You could also add the following to your .htaccess to get around this issue very easily:
    Header set Access-Control-Allow-Origin
    You could either allow every page to use it (bad idea)
    Header set Access-Control-Allow-Origin "*"
    Or you could just limit it to the domain of your translated page like this:
    Header set Access-Control-Allow-Origin "https://your-translated-domain.com"
    The .htaccess file should be in the root directory of your WP installation
Deixar uma Resposta
Por favor, mantenha-se no tópico e respeite os outros. Se você precisar de ajuda com problemas não relacionados a esta postagem, use nosso Fórum de suporte para iniciar um bate-papo ou enviar um tíquete.
Você pode usar estas tags:
