Open
Topic Tags: Compatibility
Overview of the issue
When using SiteOrigin’s Layout Builder, there are issues with translating widgets that are duplicated both inside and outside the layout builder on the same page. As result, they are not translatable.
Workaround
Please, make sure of having a full backup of your site before proceeding.
  • Open …/wp-content/plugins/sitepress-multilingual-cms/addons/wpml-page-builders/classes/Integrations/SiteOrigin/TranslatableNodes.php file.
  • Look for line 142.
  • Change:
    public function get_string_name( $node_id, $field, $settings ) {
    		return $node_id . '-' . $settings[ self::SETTINGS_FIELD ]['id'] . '-' . $field['field'];
  • For:
    	return $node_id . '-' . $settings[ self::SETTINGS_FIELD ]['widget_id'] . '-' . $field['field'];
  • Do a small modification on the original page and save.
  • Update the translation.
Deixe uma resposta
Por favor mantenha-se no assunto e seja respeitoso com os outros. Se precisar de ajuda com problemas não relacionados a este post, use nosso Fórum de Suporte para iniciar um chat ou enviar um ticket.
Você pode usar estas tags:
