跳到内容 跳到侧边栏
Open
Topic Tags: Compatibility
Overview of the issue
When using the Content Toggle widget from the Ultimate Addons for Elementor plugin, translated Elementor templates are not displayed correctly when using the Advanced Translation Editor (ATE). Instead of showing the translated template, the widget displays the original language content on the translated page.
Workaround
  • Open your theme’s functions.php file.
  • Add the following snippet:
    // WPML: Workaround for compsupp-7677
    add_filter('elementor/frontend/before_render', 'wpml_compsupp7677_translate_content_toggle');
    function wpml_compsupp7677_translate_content_toggle($element) {
        if (!class_exists('SitePress') || 'uael-content-toggle' !== $element->get_name()) {
            return;
        $settings = $element->get_settings();
        $keys_to_convert = [
            'section_content_',
            'saved_pages_',
            'section_saved_rows_'
        $modified = false;
        foreach ($keys_to_convert as $key) {
            for ($i = 1; $i <= 2; $i++) {
                $setting_key = $key . $i;
                if (isset($settings[$setting_key]) && is_numeric($settings[$setting_key])) {
                    $post_type = get_post_type($settings[$setting_key]);
                    if ($post_type) {
                        $settings[$setting_key] = apply_filters(
                            'wpml_object_id',
                            $settings[$setting_key],
                            $post_type,
                            true
                        $modified = true;
        if ($modified) {
            $element->set_settings($settings);
发表回复
您可以使用这些标签:
