跳到内容 跳到侧边栏
Open
Topic Tags: Compatibility
Overview of the issue
When using the Post Grid widget from the Unlimited Elements for Elementor plugin, the widget fails to fetch translated posts in the translated versions of the pages.
Workaround
  • Open your theme’s functions.php file.
  • Add the following code:
    // WPML Workaround for compsupp-7445
    add_filter( 'elementor/frontend/before_render', 'wpml_compsupp7445_filter_ucaddon_post_grid');
    function wpml_compsupp7445_filter_ucaddon_post_grid($element) {
        if ( 'ucaddon_post_grid' !== $element->get_name() ) {
            return;
        $settings = $element->get_settings();
        if ( isset( $settings['post_list_manual_select_post_ids'] ) && is_array( $settings['post_list_manual_select_post_ids'] ) ) {
            foreach ( $settings['post_list_manual_select_post_ids'] as $key => $id ) {
                $post_type = get_post_type( $id );
                if ( ! $post_type ) {
                    continue;
                $id = apply_filters( 'wpml_object_id', $id, $post_type, false );
                unset($settings['post_list_manual_select_post_ids'][$key]);
                $settings['post_list_manual_select_post_ids'][] = $id;
            $element->set_settings( 'post_list_manual_select_post_ids', $settings['post_list_manual_select_post_ids'] );
        if (isset($settings['post_list_manual_post_ids_dynamic'])) {
            // Check if the IDs are in a string and convert them to an array
            if (is_string($settings['post_list_manual_post_ids_dynamic'])) {
                $settings['post_list_manual_post_ids_dynamic'] = explode(',', $settings['post_list_manual_post_ids_dynamic']);
            // Proceed only if it's an array
            if (is_array($settings['post_list_manual_post_ids_dynamic'])) {
                foreach ($settings['post_list_manual_post_ids_dynamic'] as $key => $id) {
                    $post_type = get_post_type($id);
                    if (!$post_type) {
                        continue;
                    $translated_id = apply_filters('wpml_object_id', $id, $post_type, false);
                    $settings['post_list_manual_post_ids_dynamic'][$key] = $translated_id;
                $element->set_settings('post_list_manual_post_ids_dynamic', $settings['post_list_manual_post_ids_dynamic']);
发表回复
您可以使用这些标签:
