跳到内容 跳到侧边栏
Waiting for author
Topic Tags: Compatibility
Overview of the issue
When using Woodmart with WPML, you might experience an issue where some blocks are not translated on the frontend, even though translations are completed in the Advanced Translation Editor (ATE). This occurs when the title block uses the icon format that wraps the heading text inside a <span> tag or when the paragraph block is inside a slider and uses a <span> tag instead of a <p> tag.
Workaround
  • Go to WPML > Settings > Custom XML Configuration.
  • Add the following code and save.
    <wpml-config>
      <gutenberg-blocks>
        <gutenberg-block type="wd/title" translate="1" label="[Woodmart] Title">
          <xpath>//*[self::h1 or self::h2 or self::h3 or self::h4 or self::h5 or self::h6 or self::div.title or self::p or self::h2.span or self::span]</xpath>
        </gutenberg-block>
        <gutenberg-block type="wd/paragraph" translate="1" label="[Woodmart] Paragraph">
    			<xpath>*[self::p or self::span]</xpath>
    		</gutenberg-block>
      </gutenberg-blocks>
    </wpml-config>
  • Make a small edit on the original and resave it.
  • Enter the translation and resave it.
发表回复
您可以使用这些标签:
