跳过导航
Open
Topic Tags: Compatibility
Overview of the issue
If you are using WP Rocket plugin, you may notice that currency changes on product pages are not being reflected immediately. Instead, the currency only updates after refreshing the page.
Workaround
Option 1
  • Go to Settings > WP Rocket page.
  • Then in Advanced rules > Never Cache Cookies section, add this cookie:
    wcml_client_currency
Option 2
  • Add the following code into your theme’s functions.php file:
    compsupp-7372
    This filter adds ?wcmlc={currency_code} to the URL, which specifies a query string with the currency code.
    add_filter( 'wcml_is_cache_enabled_for_switching_currency', '__return_true' );
2 所有回复 给 “WP Rocket - Currency Not Changing in Products Page”
  1. WP Rocket: You are using “Dynamic Cookies Cache”. Cloudflare APO is not yet compatible with that feature.
    You should either disable Cloudflare APO or check with the theme/plugin requiring the use of “Dynamic Cookies Cache” developers for an alternative way to be page-cache friendly. More info
    https://docs.wp-rocket.me/article/1444-using-cloudflare-apo-with-wp-rocket?utm_source=wp_plugin&utm_medium=wp_rocket
    i get this notification when adding this settings you provided, can you guys please fix your plugin!
    • Thanks Ali! I added these infos to our development ticket.
      If you need any additional help regarding this, please create a new ticket or chat in our support area.
留下回复
Please stay on topic and be respectful to others. If you need help with issues not related to this post, use our Support Forum to start a chat or submit a ticket.
您可以使用这些标签:
