跳到内容 跳到侧边栏
Open
Reported for: Advanced Custom Fields Multilingual 2.1.5
Topic Tags: Compatibility
Overview of the issue
When using Advanced Custom Fields (ACF) with WPML, you might experience issues with conditional logic not functioning correctly in secondary languages. This happens when the conditional logic depends on fields that use object-based or term-based references, such as taxonomy or post object fields.
Workaround
  • Add the following code to your theme’s functions.php file.
     * WPML Workaround for compsupp-wpmltriage-3649
    add_action( 'init', function() {
    	if ( defined( 'ICL_SITEPRESS_VERSION' ) ) {
    		add_filter( 'acf/load_field', function ( $field ) {
    			if ( empty( $field['conditional_logic'] ) || ! is_array( $field['conditional_logic'] ) ) {
    				return $field;
    			foreach ( $field['conditional_logic'] as $group_index => $rules ) {
    				if ( ! is_array( $rules ) ) {
    					continue;
    				foreach ( $rules as $rule_index => $rule ) {
    					if ( isset( $rule['field'], $rule['value'] ) && is_numeric( $rule['value'] ) ) {
    						// Fetch the parent field
    						$parent_field = acf_get_field( $rule['field'] );
    						if ( ! isset( $parent_field['type'] ) ) {
    							continue;
    						if ( $parent_field['type'] === 'taxonomy' ) {
    							$rule['value'] = apply_filters( 'wpml_object_id', $rule['value'], $parent_field['taxonomy'], true );
    						} elseif ( $parent_field['type'] === 'post_object' ) {
    							$post_types = $parent_field['post_type'] ?? ''; // can be multiple
    							if ( is_array( $post_types ) ) {
    								foreach ( $post_types as $post_type ) {
    									$translated_id = apply_filters( 'wpml_object_id', $rule['value'], $post_type, true );
    									if ( $translated_id && $translated_id !== $rule['value'] ) {
    										$rule['value'] = $translated_id;
    										break;
    							} else {
    								$rule['value'] = apply_filters( 'wpml_object_id', $rule['value'], $post_types, true );
    						$field['conditional_logic'][ $group_index ][ $rule_index ] = $rule;
    			return $field;
    		}, 100 );
发表回复
您可以使用这些标签:
