跳到内容 跳到侧边栏
Open
Topic Tags: Compatibility
Overview of the issue
When using Elementor PRO’s Posts widget with the post type translation preference set to “Translatable – use translation if available or fallback to default language”, the pagination links may become incorrect, pointing to the wrong pages.
Workaround
You can resolve this issue by using one of the following approaches:
1. Change the translation option
If you don’t need “Translatable – use translation if available or fallback to default language”.
  • Go to “WPML > Settings > Post Types Translation”.
  • Set the translation preference to “Translatable – only show translated items”.
2. Enable individual pagination in the widget
  • Edit the original page using the Posts widget in Elementor.
  • In the widget settings “Content > Pagination” enable the “Individual Pagination” option.
  • 发表回复
    您可以使用这些标签:
