跳过导航
Open
Topic Tags: Compatibility
Overview of the issue
When using the Enfold theme, XML code inserted into a code block (via the code element) appears correctly in the main language. However, in translated posts, the XML code is stripped out.
Workaround
  • Open …/wp-content/plugins/sitepress-multilingual-cms/addons/wpml-page-builders/classes/Integrations/Enfold/class-wpml-compatibility-theme-enfold.php file.
  • Look for line 45.
  • Just after:
    		if ( wp_is_post_revision( $post_id ) ) {
    			return;
  • Add the following code:
    		// Check if the post content contains an Enfold Code Block.
    		if ( strpos( $post->post_content, '[av_codeblock' ) !== false ) {
    			// Skip processing if Enfold Code Block is detected.
    			return;
留下回复
紧扣主题并尊重他人。如果您需要帮助解决与本帖无关的问题,请使用我们的 Support Forum 开始聊天或提交票据。
您可以使用这些标签:
