跳过导航
Open
Topic Tags: Compatibility
Overview of the issue
When using the new Product Safety feature from Germanized, there is an issue with translating manufacturer data and syncing these details in product translations.
Workaround
1. Ensure manufacturers are correctly translated
  • Navigate to Products → Manufacturer.
  • Verify that all manufacturer terms are translated and saved properly.
2. Set the translation preference
  • Go to WPML → Settings → Custom Fields Translation.
  • Click on “Show system fields”.
  • Locate the field '_manufacturer_slug' and set its translation preference to Copy Once.
  • 3. Edit the original to update the translation
    • Make a small change in the original product (like adding a space after a paragraph) and save.
    • The manufacturer data and related fields will automatically sync to the translation.
    留下回复
    紧扣主题并尊重他人。如果您需要帮助解决与本帖无关的问题,请使用我们的 Support Forum 开始聊天或提交票据。
    您可以使用这些标签:
