跳到内容 跳到侧边栏
Waiting for author
Topic Tags: Compatibility
Overview of the issue
When using Kadence theme with the Kadence PRO plugin, templates assigned to WooCommerce product category archives may not be applied correctly to their translated versions.
Workaround
1. Template Rendering Fix
  • Open the …/wp-content/plugins/kadence-pro/dist/elements/elements-init.php file.
  • Look for line 2035.
  • Replace:
    if ( in_array( $queried_obj->term_id, $show_taxs ) ) {
  • With:
    if ( defined( 'WPML_PLUGIN_FILE' ) ) {
    	$my_default_lang = apply_filters( 'wpml_default_language', NULL );
    	$queried_obj->term_id = apply_filters( 'wpml_object_id', $queried_obj->term_id, $queried_obj->taxonomy, true, $my_default_lang );
2. Post ID Translation Fix
  • In the same file, look for line 2018.
  • Replace:
    $current_id = get_the_ID();
  • With:
    	$current_id = apply_filters( 'wpml_object_id', $current_id, 'post', true, $my_default_lang );
3. Conditional Header Template Fix
The same issue occurs with conditional headers, where they are not applied to translated versions of content.
  • Open the …/wp-content/plugins/kadence-pro/dist/conditional-headers.php file.
  • Look for line 1287.
  • Apply the same change as done in Point #1, on line 2035 of the previous file.
发表回复
您可以使用这些标签:
